JBasham
JBasham Reader
11/17/16 9:35 a.m.
Greetings, I just bought one of these and I would like to know the mnfr-recommended charging voltage. I can't find it on their web site. Anybody know what it is?
If it's one of those AGMs that wants 15+ volts, then I need a new AMG BatteryMinder. But some AGMs just want the 14+ charging voltage, and I could keep using my regular BatteryMinder.
iceracer
iceracer PowerDork
11/17/16 10:17 a.m.
Owners manual ?
11/17/16 10:22 a.m.
It seems it really isn't listed anywhere. I'd think it will accept the usual lead-acid charge voltage range, otherwise people would be screaming about all the dead Shuriken batteries by now. AFAIK most AGMs also accept the usual charge voltage range.
Bobzilla
Bobzilla UltimaDork
11/17/16 10:44 a.m.
I used the same one in the Forte for 3 seasons. Topped off during hte winter with my normal battery charger set at 2A. IT still has a charge, but isn't enough to start 2.4L of high copression awesomeness below 60*F
EDIT: The Forte tops out at 14.6V so I'd say you are perfectly fine.
JBasham
JBasham Reader
11/17/16 11:01 a.m.
Awesomeness. Thanks. If I wind up killing it early in a year or something, I'll come back and update.
Bobzilla
Bobzilla UltimaDork
11/17/16 11:05 a.m.
What are you stuffing it into? I never had any problem with starting, running, running the AC/stereo etc. IMO it's a great value.
jstein77
jstein77 UltraDork
11/17/16 12:05 p.m.
That's an odd looking terminal. How did you attach your battery cables?
11/17/16 12:08 p.m.
^That's a common terminal used on small 12v batteries used on UPSes, security systems, electric wheelchairs etc. It wouldn't be rocket science to make a terminal adapter, I'm more worried about how those terminals would handle the kind of current a car could draw, especially when starting.
It looks like all the SK-BT20s have a bolt-type or post-type terminal though.
Bobzilla
Bobzilla UltimaDork
11/17/16 12:56 p.m.
GameboyRMH wrote: ^That's a common terminal used on small 12v batteries used on UPSes, security systems, electric wheelchairs etc. It wouldn't be rocket science to make a terminal adapter, I'm more worried about how those terminals would handle the kind of current a car could draw, especially when starting. It looks like all the SK-BT20s have a bolt-type or post-type terminal though.
Correct. That was mine. I bought a pair of hte top post adapters.
wXyTE9jHeI2T2CUS1QI3HEQa1mNGIIwrCR0EKt7oS3T9afiajqzkRtrXBPHbVuvh
