Digging through the suspension box (it's truly amazing how much crap I have accumulated over the years), I ran across this bag of stuff, which I think came with one or another car. I'm pretty sure the white plastic split washers are for the top of Koni yellows. Does anyone know what the rest of this stuff is for?
Beige are shock/damper bump stops. Made of a urethane foam type material.
EvanB
MegaDork
4/1/20 9:39 a.m.
They look like the Fat Cat Miata shock mount bushings.
http://fatcatmotorsports.com/FCM_Bilstein_mounts_NA.htm
In reply to EvanB :
That's It! Thanks for the pointer. I'm pretty sure they came in the boxes of stuff that were included in my '94 Miata. There's a set of Koni yellows on the shelf waiting to go into the Miata so this will come in handy. Have the NB shock mounts too, so now I need to see if I can locate the bump stops.
Jim
Whats the inner diameter of the holes? Either bumpstops or end link bushings
In reply to ChrisLS8 :
Chris - Don't think so, what I have matches up exactly with the FCM shock mount kit. Found the rest of the kit - '99 shock hats and the bump stops in another box. The only thing I'm missing is the NA spring spacers. It's really cool to have found this stuff - the Miata is the next project after I get brakes and suspension on the 3.
Jim
don't forget the blue loctite when you screw them together
