aussiesmg
aussiesmg UltimaDork
10/25/12 10:26 a.m.
Does anybody have a schematic for a basic wiring loom, with headlights, wipers and basic engine wiring for a carbed vehicle.
I need to rewire the Mustang and need to be sure I get it right the first time.
Steve
yamaha
yamaha Dork
10/25/12 10:36 a.m.
I don't right now, but I'm going to keep an eye on this.......I'm going to rewire the ti's lighting system separate of the engine harness to expedite different engine configurations.
N Sperlo
N Sperlo PowerDork
10/25/12 10:43 a.m.
I'd just put everything on a different switch run to whatever relays you may be using. My cavalier only has two switches and a button. Ignition, fan, push start. No lights, though. If I were to put some in, I'd just add a separate switch with whatever relays it called for. I can draw up a schematic later. Can you tell me exactly what you are running power to? Just engine, wipers, and lights? I could probably build one as well given proper dimensions.
JohnInKansas
JohnInKansas HalfDork
10/25/12 10:49 a.m.
If you're running a 1/4 turn master cutoff switch, make sure you run battery, ignition, AND alternator/generator through it.
AngryCorvair
AngryCorvair PowerDork
10/25/12 12:23 p.m.
aussiesmg wrote: Does anybody have a schematic for a basic wiring loom, with headlights, wipers and basic engine wiring for a carbed vehicle. I need to rewire the Mustang and need to be sure I get it right the first time. Steve
do you desire turn-key with original switches for stuff, or are you going with toggles and buttons and such?
i'm sure i've got something at home i can scan and send you, from the V8Vair and/or the V8 944.
alfadriver
alfadriver PowerDork
10/25/12 4:03 p.m.
any chance you can get a copy of your wiring harness?
I got a copy of the original harness, and erased what I didn't want. Then fabricated it.
Kenny_McCormic
Kenny_McCormic Reader
10/25/12 4:24 p.m.
I would just run each circuit as needed, and then loom it.
logdog
logdog Reader
10/25/12 4:32 p.m.
Unless you already have a bunck of the wiring I dont know if you could beat a premade 12 circuit kit as a start. I rewired a truck with a Painless kit but if I were to do it again I would buy one of these. They are cheaper and I helped install the EZ branded harness in another truck owned by a friend. http://www.ezwiring.com/wiring_harness.html
AngryCorvair
10/25/12 5:09 p.m.
alfadriver wrote: any chance you can get a copy of your wiring harness? I got a copy of the original harness, and erased what I didn't want. Then fabricated it.
i assume you mean 'diagram' instead of 'harness'.
that's what i did on the V8Vair, then i pretty much used the V8Vair diagram to design the V8 944 harness.
aussiesmg
10/25/12 5:10 p.m.
In reply to AngryCorvair:
Its a challenger Pat, no need for a key start, anything you can offer would be hugely appreciated.
aussiesmg
10/25/12 5:12 p.m.
logdog wrote: Unless you already have a bunck of the wiring I dont know if you could beat a premade 12 circuit kit as a start. I rewired a truck with a Painless kit but if I were to do it again I would buy one of these. They are cheaper and I helped install the EZ branded harness in another truck owned by a friend. http://www.ezwiring.com/wiring_harness.html
Awesome deal but still not challenge friendly... enough.
Moving_Target
Moving_Target Reader
10/27/12 3:35 p.m.
Helps?
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-86-Body-Diagram.gif
Edit: To be honest though, The carbed cars wiring harness isn't that complicated to begin with so I doubt you'll remove much weight.
aussiesmg
4/3/13 7:46 a.m.
Helps? http://www.veryuseful.com/mustang/tech/engine/images/Mustang-86-Body-Diagram.gif Edit: To be honest though, The carbed cars wiring harness isn't that complicated to begin with so I doubt you'll remove much weight.
86 5.0 efi car has 25lbs of wiring. Plus the original loom was hacked up and scotch locked.
Resurrecting this because the old loom is out and the new starts when I get the caged shell back
AngryCorvair
4/3/13 7:58 a.m.
do you have the OE ignition switch, wiper switch, turn signal switch, brake light switch? do you still have the original (albeit hacked and scotch-locked) harnesses for the whole car?
aussiesmg
4/3/13 8:12 a.m.
Yes I have all the old parts, pretty damn heavy too
RossD
RossD UberDork
4/3/13 8:30 a.m.
For some reason when you look up dune buggy wiring kits, they seem much cheaper.
Gasoline
Gasoline Dork
4/3/13 11:21 a.m.
Is keeping wipers a judging benefit? or?
yamaha
yamaha UltraDork
4/3/13 11:50 a.m.
In reply to Gasoline:
I deleted mine......they weighed too much.
Gasoline
Gasoline Dork
4/3/13 12:26 p.m.
yamaha wrote: In reply to Gasoline: I deleted mine......they weighed too much.
Thanks! I will keep in in the bottom of the 55 gal junk drum.
For Steve: This is a pretty basic idea (w/ relays) for a race car
You need this one also: GoGo
Swank Force One
Swank Force One MegaDork
4/3/13 12:28 p.m.
I thought we were required to keep wipers and lights on Challenge cars...
Gasoline
Gasoline Dork
4/3/13 12:43 p.m.
This is all I saw:
'6. Cars must be roadworthy, meaning basic street equipment must be present: functioning headlights, uncracked windshields, battery tie-down straps, working brake lights, working horn and DOT-approved tires.
yamaha
yamaha UltraDork
4/3/13 12:53 p.m.
berkeley, the ti's horn quit working, so it was removed.....will a small hand ball horn work?
AngryCorvair
4/3/13 1:51 p.m.
yamaha wrote: In reply to Gasoline: berkeley, the ti's horn quit working, so it was removed.....will a small hand ball horn work?
you would not be the first to employ a manual horn on a challenge car.
TxCoyote
TxCoyote New Reader
4/3/13 6:09 p.m.
Did the same in the RX7 race car
16UU853AGJUrCLoQhTfQfQ50VwaCIwYT3bNsn4Ar2BrwbZBeqgTPmlmHgjlpDhQL
