failuer
failuer New Reader
12/12/13 8:01 a.m.
I have a theory that a recent dead battery on a 2001 Civic is the result of a short work commute and the inability for the car to recharge itself from the drain of the start.
Does anyone know if there's a general 'time it takes to recover from a start' amount of time?
If not I should be able to calculate a ball park figure by looking at the cranking amps of the starter, and the output of the alternator?
I could probably go a bit further and see how long it would take to drain the battery by taking that number and applying it to the amp hours of the battery?
mad_machine
mad_machine MegaDork
12/12/13 8:12 a.m.
it's possible. The Battery is probably dying a sulfery death as it never completely recharges
wbjones
wbjones PowerDork
12/12/13 8:17 a.m.
maybe … my commute was 2 miles (for 13 yrs) and the OEM battery in my Integra lasted 8 - 9 yrs ….
11110000
11110000 Reader
12/12/13 9:31 a.m.
It can be calculated, but it will depend on the size/health of your battery, size/health of the alternator, and even the temperature on any given day.
A short commute is probably a harder life for a battery, but as a general rule, 10min of driving should be more than sufficient to replenish the drain from a start.
iceracer
iceracer UberDork
12/12/13 9:41 a.m.
If you put a voltmeter on the car you will see that it takes a very short time to recharge from a start. Most likely your battery was on it's death bed.
failuer
failuer New Reader
12/12/13 1:22 p.m.
Thanks fer the input. This commute is probably less than a mile. I had it charged/checked at autozone who reported it OK. I'll double check the alternator but I've dispensed the advice to take it for a longer drive or leave it running for 10 min every few days.
3wmmdUWfhRXjz6E3QOVQbidLOxDwaQ2C9ezqsX5txy8Vz4Srgmww8DS61eH0Sm1M
