Before we could return to the track with our new Bridgestone RE-71RS tires and Apex wheels, we needed to do an oil service on our Porsche 997. While it had only been a couple of thousand miles since its last oil change, that was also two years ago.
I first saw the image with the title "Fresh Oil for the Track" and thought "Why would they put fresh oil on the track?" That's not usually considered a performance enhancing activity. Maybe a new car control exercise? Probably not.
Happy Holidays and Happy New Year!
That air blower and vacuum don't do it to clean out the radiators. Stuff gets packed into the corners as well as in between the radiator and AC condensers. You need to remove the front bumper cover, air ducts and then separate the radiators from the AC condensers. Look at my 996 turbo thread for the pics of what I found on my low mileage car...
Probably more than that if you have a dealer do it. This looks like it was probably about $180 in materials. But the oil doesn't need to be that expensive. My cayman oil changes are about $100 all in, but I use amsoil euro blend at like $9/quart.
The thing to do with the radiators is to clean them out real well like docwyte described and then put some kind of screen in the grille openings. Then you just pick the little bit of debris that piles up out of the corner every now and then.
docwyte said:That air blower and vacuum don't do it to clean out the radiators. Stuff gets packed into the corners as well as in between the radiator and AC condensers. You need to remove the front bumper cover, air ducts and then separate the radiators from the AC condensers. Look at my 996 turbo thread for the pics of what I found on my low mileage car...
100% Here's a picture of mine. The bottom 1.5" was completely plugged with compost and sand. It would be worth an extra half hour to take a peek if it hasn't been done recently.
Yeah, I spend around $100 in oil/oil filter for mine. ~9 quarts of M1 and a Mahle filter.
That's about what I found in my car, same thing packed in the corner of the AC condenser. So ended up with two huge piles of leaves/debris on either side when I was done.
Porsche gets an A for oil filter design, and a D- for lack of a dipstick. This would be the easiest oil change ever if it weren't for the stupid electronic oil fill sensor that seems to have roughly 5mL between "too full" and "not full enough".
In reply to ShinnyGroove (Forum Supporter) :
Well, you're not really supposed to have it all the way full on the gauge. 1-2 bars down is where you should set the oil level. Sadly Porsche is hardly the only car company sending cars out without dipsticks.
ShinnyGroove (Forum Supporter) said:Porsche gets an A for oil filter design, and a D- for lack of a dipstick. This would be the easiest oil change ever if it weren't for the stupid electronic oil fill sensor that seems to have roughly 5mL between "too full" and "not full enough".
on my new to me Porsche the car has a canister style oil filter. Is that inferior to the P-car design in some way? I purchased a 997.1 /w an LN engineering 4.0l motor in it.
Canister filter is generally considered an upgrade. Not exactly sure it's better at filtering, but I think it's a bit safer and more robust (the plastic threads on the filter housing sketch me out a little bit every time I tighten it). Maybe cheaper too, or at least more readily available?
GCrites80s said:I seem to recall dealer oil changes on these being $300+.
No, Hyundais get oil changes. Porsches get oil services.
I just liked that the oil filter/housing was easy to reach and pointing straight down from the engine so it could be removed without dumping out half a quart of oil on everything.
