DirtyBird222
DirtyBird222 UberDork
5/9/20 6:47 p.m.
My 2001 Sequoia tailgate window keeps getting hung up. The motor is fine and the tracks are dirty/bone dry. Any recommendations would be greatly appreciated
Dusterbd13-michael
Dusterbd13-michael MegaDork
5/9/20 6:50 p.m.
Subbed for the answer
EvanB (Forum Supporter)
EvanB (Forum Supporter) MegaDork
5/9/20 7:13 p.m.
noddaz
noddaz UltraDork
5/9/20 7:27 p.m.
Nissan actually had/has window regulator grease.  I have no idea if it is any good.  I just remember seeing it when I worked at a Nissan dealer.
Scott
dean1484
dean1484 MegaDork
5/9/20 9:38 p.m.
Waterproof grease is what you want. I use the stuff for outboard lower ends. You can get it at NAPA.
dean1484
dean1484 MegaDork
5/9/20 9:44 p.m.
This stuff. I got it a couple years back and use it in any thing that can get wet.
1988RedT2
1988RedT2 MegaDork
5/10/20 6:11 a.m.
EvanB (Forum Supporter) said:
Sil-glyde
https://agscompany.com/product/sil-glyde-silicone-lubricant-tube-4-oz/
Seconded.  I use it sparingly on lots of things, including brake caliper pins.  Very slickery, stays put.
I've had a couple tubes on hand for years.  Looks like they've modernized the packaging.
dean1484
dean1484 MegaDork
5/10/20 9:48 a.m.
Sil-glyde
I am going to try that as well.
dean1484
dean1484 MegaDork
5/10/20 9:50 a.m.
That stuff is expensive!!!  $10/4oz. It is a silicon based so it should work really well.
jimlowe
jimlowe New Reader
5/10/20 10:31 a.m.
The creme de la creme of window track grease favored for slow old Miata windows around the world:
https://www.amazon.com/Honda-Genuine-Shin-Etsu-Grease/dp/B006Z9TZ9M
pres589 (djronnebaum)
5/10/20 10:40 a.m.
I always had okay luck with white lithium grease meant for garage doors.  Maybe my simple tastes ran too simple?
pirate
pirate HalfDork
5/10/20 10:43 a.m.
Lithium grease is often used in marine applications and is considered water proof. It's usually white in color really slick and a little bit goes a long way.
5/10/20 1:41 p.m.
In reply to pirate :
You can also get it everywhere and it's pretty cheap.
TJL (Forum Supporter)
TJL (Forum Supporter) HalfDork
5/10/20 1:52 p.m.
I like my cheap-ish bottle of "silicon grease" from amazon. Ive found a ton of uses for it. Window tracks being one of them.
Aaron_King
Aaron_King PowerDork
5/10/20 5:58 p.m.
In reply to dean1484 :
Looks like NAPA has it rebranded, 8oz for $14:
Napa 7651346 SIL Glyde Silicone Lubricating Compound Tube, 8 oz.
DirtyBird222
5/11/20 9:48 a.m.
I ended up going with some knock off brand from the ACE Hardware I can walk to from my apartment. It worked pretty well and the window goes up and down without getting bunged up on its way down now. I did have to clean a lot of dirt and buildup out of the tracks as well. I left it apart as I'm going to put some new sliders in the regulator tracks. They look beat to hell. It was nice to keep the denso window motor in too, the replacement I got from rock auto A) didn't come with a proper connector (which only adds to the list of steps when replacing a window motor) and B) seemed to struggle in bench testing.
The other annoying part of this 2001 Sequoia. I went to change the hood struts as well, very impressed the OEM ones lasted almost 20 years. Toyota must have planned for them to last indefinitely because the lower part is "permanently" affixed to the ball stud that bolts into the fender well. Never thought I would have to use a cutting wheel to get a ball stud off a hood strut.
DirtyBird222
5/11/20 9:48 a.m.
Also much thanks for the guidance/info!
ShinnyGroove (Forum Supporter)
ShinnyGroove (Forum Supporter) Reader
10/25/20 6:32 p.m.
That Shin Etsu grease is great.  It soaks into the rubber and softens it like new. The surface is slippery but not greasy, and doesn't pick up dirt as fast.
asJfn6PWGXiqTXnGQEqWZNCXPlya9Hg3L1fmwaOuMgX1Pk3ivKGZKFB8DOKpJ1sz
