bonylad
bonylad Reader
10/26/20 8:53 a.m.
I have been told all sorts of things, but I want to hear what GRM has to say.
Cam is the exhaust cam from my 07 BPY 2.0 GTI. Has some scoring. Never had an issue per se, but I want to make sure all goes back together better than I found it.
Its a steel cam in a aluminum head.  Obviously.
I have heard WD40 and emory cloth, I have hear Muriatic acid and scotchbrite pads, I have heard quite a few ways and just dont which way to go!
Professor_Brap (Forum Supporter) UltraDork
10/26/20 8:56 a.m.
In reply to bonylad :
Wd-40 and emory cloth is my go to.
Never had a issue with it.
akylekoz
akylekoz SuperDork
10/26/20 9:42 a.m.
What ever you use wash it six times with soap and water afterwords.
slowbird
slowbird SuperDork
10/26/20 10:05 a.m.
I always heard wiping the lobes is bad. cheeky
bonylad
bonylad Reader
10/26/20 11:10 a.m.
Appreciate that.  Doesnt need much - enough to make me feel I left it better than it was.
bonylad
bonylad Reader
10/26/20 11:10 a.m.
In reply to slowbird :
Not the lobes, just the journals.
bonylad
bonylad Reader
10/26/20 11:11 a.m.
In reply to akylekoz :
Roger.
10/26/20 4:12 p.m.
The 3/4" wide strips of emery paper are perfect for this.  Used to keep big rolls of the stuff, 300 grit.  You can also "kill" it by rubbing the friction surface against itself in kerosene or penetrating oil, makes it more of a polishing paper than a cutting abrasive.
oldeskewltoy
oldeskewltoy UberDork
10/26/20 4:29 p.m.
can you catch a finger nail on that??   When I need to, I'll take the cam to the machine shop and get the journals buffed... doesn't cost a great deal....
My bigger concern is,  1) the cam journal in the head...  and 2) if the clearances will be ok after you buff the cam, and "address" the journals.....
noddaz
noddaz UltraDork
10/26/20 4:31 p.m.
This!  What does that journal on the head look like?
Furious_E (Forum Supporter)
Furious_E (Forum Supporter) UltraDork
10/26/20 4:36 p.m.
Wouldn't muriatic etch the metal? That seems undesirable.
bentwrench
bentwrench SuperDork
10/26/20 4:58 p.m.
The acid would be for de-rusting. Not going to do much for the finish...
Opti
Opti Dork
10/26/20 7:12 p.m.
As mentioned can you catch a finger nail on it? My go to has always been ignore it if It doesn't catch a fingernail. Heck sometimes when I can catch a fingernail I still ignore it (GM cam bearings, I'm talking about you).
Emery cloth would be my go to, If I thought it was too bad.
Is that the 2.0 TSi motor? If it is, I'd be a little more careful than most, I know some of them have weird idle oil pressure issues, from tore up cams and cam bridges
bonylad
bonylad Reader
10/26/20 8:19 p.m.
It's a FSI engine. Yes. The head looks fine as does the cam girdle. Maybe a little bit but nothing bad. IMO. The journals do catch a little of the nail. I had no issues. And short of pullin this to replace the intake cam. Would have never noticed it. I'll take pics in the morning. Thanks fellas.
Paul_VR6 (Forum Supporter)
Paul_VR6 (Forum Supporter) Dork
10/27/20 7:49 a.m.
This, Also may happen to the next one if it got a slug of junk in there that is cleaning out of the oil port in the head, esp if it's just the one bearing surface. I would think these stock cams are cheap/easy to find though if you don't want to fool with it.
bonylad
bonylad Reader
10/27/20 3:51 p.m.
In reply to Paul_VR6 (Forum Supporter) :
The cam isn't the issue per se. more the journals.
Birthdays
o81quV9j8jWxLZt8zR0jatH83JLxZbsR8AjFhQOXuuWgZ3zTohn3J48zQiLjqMGu
