DjGreggieP
DjGreggieP HalfDork
12/22/21 10:10 a.m.
So I have been fighting exhaust leaks on the GMW for a while, and the biggest concerning one is the exhaust leaking into the cabin. I believe its coming in around the shifter surround.
I need to pull it apart yet, but due to the previous owner installing a T5 transmission, I am best guessing the OEM rubber boot around the shifter is long gone, and the actual surround has a broken tab as well. It really cuts down the enjoyment of driving this thing.
What is the go to for rubber sheeting for sealing in such an area? I do have a plan to *hopefully* fix the leak in the header (replacement after a bit more measurements to hopefully fit manifolds) but sealing the exhaust OUT of the cabin would be glorious as well.
ross2004
ross2004 Reader
12/22/21 10:13 a.m.
John Welsh
John Welsh Mod Squad
12/22/21 10:15 a.m.
Keeping the exhaust gas in the exhaust pipes is likely your best defense.
DjGreggieP
DjGreggieP HalfDork
12/22/21 10:41 a.m.
In reply to ross2004 :
That just might do it... I should check with some of the local drag racers if anyone is needing to update some expired gear...
In reply to John Welsh:
That is the overall goal, but the absurdity of how they fit the header in there, while impressive, is making taking measurements a bit difficult presently. I know its leaking at the flange as well as somewhere among the welds under the heat wrap on it. I need to pull the steering shaft as well as possibly pull the engine to facilitate the removal of the current header.
z31maniac
z31maniac MegaDork
12/22/21 10:43 a.m.
This.
iansane
iansane HalfDork
12/22/21 10:59 a.m.
But then you don't get to hear those fancy colors after driving long distances.
matthewmcl
matthewmcl HalfDork
12/22/21 11:02 a.m.
While sealing the exhaust should be number 1, patching the hole is also useful. I buy rubber sheet from McMaster.
Datsun310Guy
Datsun310Guy MegaDork
12/22/21 11:31 a.m.
I sell rolls of rubber.  Maybe a sample....
thickness?  Width? Length?
sometimes I go to McMaster too.....
Trent
Trent PowerDork
12/22/21 12:17 p.m.
Steele Rubber products
https://www.steelerubber.com/search?q=shift+boot
Metro Molded parts
https://metrommp.com/detail-items/boots-bellows/shift-boot/
Both are excellent sources for automotive and RV rubber. Vehicle specific and universal stuff
If you are dealing with a classic italian car http://www.cicognaniguarnizioni.it/ Has the best stuff I have found, and is worth dealing with the language barrier and shipping obstacles
xi6HCX8DmqXPE6879QCdRidmtrfdjr053OztxwzSjMVZtG6z0kFaVbEuHrSeOQKR
