racer_ace
racer_ace New Reader
9/24/08 7:57 p.m.
Any advice on the best way to clean up chassis ground connections? What works best; sand paper/emery cloth, CRC electrical contact cleaner, baking soda and water, other??? Thanks in advance for your input.
-Ray
Sonic
Sonic New Reader
9/24/08 7:59 p.m.
I just sand them until clean and shiny with whatever is handy
Dr. Hess
Dr. Hess SuperDork
9/24/08 9:13 p.m.
I have a cordless Dremel Brand Moto Tool that I put a wire wheel in. Works great. Otherwise, whatever sand paper is handy.
grtechguy
grtechguy SuperDork
9/24/08 9:15 p.m.
yup...sand till shiney
foxtrapper
foxtrapper SuperDork
9/25/08 5:28 a.m.
Clean grounds is a two step process. One is the cleaning, the other is the keeping clean. Vaseline makes a dandy protectant.
wreckerboy
wreckerboy SuperDork
9/25/08 7:13 a.m.
Sand until shiny. Assemble. Apply Vaseline liberally. If you live in the rustbelt repeat as required if you don't want to chase phantom electrical issues, or just wait until you do and then look for another solid piece of metal to attach the ground to.
nickel_dime
nickel_dime HalfDork
9/25/08 7:35 a.m.
foxtrapper wrote: Clean grounds is a two step process. One is the cleaning, the other is the keeping clean. Vaseline makes a dandy protectant.
K-Y Jelly
See there is another use for it.
914Driver HalfDork
9/25/08 8:05 a.m.
Instead of K-Y, I use dielectric grease. It allows electrical continuity better than most.
Dan
Dr. Hess
Dr. Hess SuperDork
9/25/08 8:24 a.m.
KY is water soluable, and might be water based, I forget. I'm not sure that's the best thing for protecting the connection. I use dielectric grease if I have any, otherwise wheel bearing grease.
SoloSonett
SoloSonett Reader
9/25/08 8:37 a.m.
Yep, K-Y is better for other.... wetter... aplications.
Vasolene.. on the tip o my.... ( sorry Howard is on )
Put a penny on the connection and watch it grow like a Chia Pet
racer_ace
9/25/08 9:19 p.m.
Thanks everyone! Sandpaper and Dielectric grease or Vaseline it is. :-)
yzeysI1cSfp7Qre7weZKJpwHbaUPPPLgLRqJIkmI7bLBnbLZFOaCUvY4sDZC30Jk
