californiamilleghia
californiamilleghia Dork
2/16/20 4:24 p.m.
Hi ,
i want to drill  a hole in each of my tail lights to mount some back up / rear view cameras  on my van ,
the hole is about 19mm / 3/4 inch ,
What is the best way to do this and not crack the lens ?
Thanks for your ideas......
Mr_Asa
Mr_Asa Reader
2/16/20 4:25 p.m.
Go up in stages.  Maybe with a step drill?
wheelsmithy
wheelsmithy UltraDork
2/16/20 4:47 p.m.
use silicone glue to attach a washer, thoroughly tape off, and sandblast the hole.
Excessive, I know, but the question was for the best way to do it.
ShawnG
ShawnG UltimaDork
2/16/20 4:59 p.m.
Step drill.
Gearheadotaku
Gearheadotaku UltimaDork
2/16/20 6:03 p.m.
Go slow, you want to cut a hole, not melt one.
Slippery
Slippery UltraDork
2/16/20 6:30 p.m.
Dont push hard, let the drill bit do the work.
Vigo MegaDork
2/16/20 9:39 p.m.
Main thing is not to let the plastic get too hot. If you go too far with heat it'll fubar the whole project.
tr8todd
tr8todd SuperDork
2/17/20 7:54 a.m.
Once you have a pilot hole, use a hole saw and spin the drill backwards.   That's how we cut the holes in fiberglass tub surrounds.  Spinning forward, the teeth of the saw can grab as it finishes the cut and crack off a huge chunk.  So, whenever you have to cut a hole in something that can crack, spin it backwards.  Same trick works on vinyl siding when its cold.  Mount the saw blade backwards to make your cuts and you won't shatter the siding.
matthewmcl
matthewmcl Reader
2/17/20 1:02 p.m.
I have used the step drills (Christmas Tree bit) to put holes in acrylic motorcycle windscreens to good effect.
Matthew
44Dwarf
44Dwarf UberDork
2/17/20 7:21 p.m.
uni-bit  single flute drill
jkKVMMh7veRO38GA4nwJCWM0k9bqTQPmGoCsRERFoa1w8t4kGobaIJqpZyE7UFgi
