N Sperlo
N Sperlo Reader
4/25/11 11:32 a.m.
Put some newspaper down and pour coca-cola on it. Do the kitty litter grind on the rest.
donalson
donalson SuperDork
4/25/11 11:33 a.m.
i've just been using cheapo kitty litter... at the end of a work day dump a bit on and cover it well... spread it... stomp a little... leave it over night... sweep up the next day.
Rusted_Busted_Spit
Rusted_Busted_Spit Dork
4/25/11 11:52 a.m.
donalson wrote: i've just been using cheapo kitty litter... at the end of a work day dump a bit on and cover it well... spread it... stomp a little... leave it over night... sweep up the next day.
That is what I do, seems to work well.
wearymicrobe
wearymicrobe Reader
4/25/11 1:34 p.m.
If you grind it up into a dust it will pull the oil out even better. have a big motor and pestle in the garage to I picked up for like a buck to do it. Takes hours not days to get the oil out
jimbbski
jimbbski Reader
4/25/11 5:16 p.m.
I'm with the kitty litter crowd. Grind it in and then let it sit a while, then sweep it up. the remaining stain can be reduced by using powered or liquid detergent. Make a thick paste using a minimum of water, spread it on the stain and then cover it to keep it from drying out. Later just rinse it off. Gets about 99% of the oil. Time gets the rest.
DILYSI Dave
DILYSI Dave SuperDork
4/25/11 6:22 p.m.
Shotgun?
turboswede
turboswede SuperDork
4/25/11 6:55 p.m.
Dammit Dave. You beat me to it....
3brokenhondas
3brokenhondas New Reader
4/25/11 6:57 p.m.
miata?
LennyX
LennyX
11/17/11 2:30 p.m.
The kitty litter & sawdust is great for getting any fresh spills, but does little for what has dried. The acid is not a good ide as it provokes erosion and weakens the surface of the cement making it more prone to cracking or chipping.
One product that works well is Genesis 950. Genesis 950 has been used in the printing industry for the past 20 years to remove ink from press equipment, floors and clothing. Because of it's effectiveness, garages, detailers and body shops have begun using Genesis 950 not just to remove oil stains, but also to clean transmissions, interiors, tools and rags.
You can get more info on it at www.amerikalstore.com
Genesis 950 works with water to soak into a stain and break the bonds of the stain. Once a stain's bonds have been broken, the stain can actually be lifted from the surface and removed. This makes cleaning concrete and flooring a quick and easy process. To properly remove grease and oil stains from concrete, mix 1 part Genesis 950 to 7 parts water. Apply this mixture to the stained concrete or flooring and let it soak into the surface for about 2 minutes. After it has soaked into the surface, use a push broom or scrub brush on the area. This will get the mixture into the stain and allow the bond of the stain to be broken. After scrubbing the area, power wash the surface with water and the stain will be removed. For heavier stains, the process may be repeated or the mixture may be allowed to soak on the stain for a longer duration of time.
Being an all purpose cleaner, Genesis 950 can also be used for detailing and interior cleaning. By using the same mixture of 1 part Genesis 950 to 7 parts water, dashboards, upholstery and floors can be cleaned with a sponge. The mixture will take out stains, and clean the interior of dust, dirt and grime. Oil and grease can easily be removed from transmissions, chains, rims, grills, and bodys. It is also the perfect solution for cleaning and restoring convertible tops and vinyl.
Half the battle of maintaining a car is maintaining the garage or your driveway. Removing grease and oil stains can be easy if you know how to do it properly and use the right tools.
yamaha
yamaha Reader
11/17/11 2:38 p.m.
crud cutter........
purple power works too, just not as well
RossD
RossD SuperDork
11/17/11 2:38 p.m.
Stain the rest of the concrete a consistant color? Don't look down?
benzbaron
benzbaron Dork
11/17/11 2:45 p.m.
If you do it right you can end up with calico driveway. The oil makes black spots, the transmission fluid makes red spots, and the leaky battery makes white spots.
Merc
Merc New Reader
11/17/11 2:51 p.m.
In reply to LennyX:
Wow LennyX you sound like an infomercial! Are there any special offers?
corytate
corytate HalfDork
11/17/11 3:28 p.m.
several cycles of DriveUp, scrub, wash, pressure wash
cwh
cwh SuperDork
11/17/11 3:34 p.m.
Driveways are going to get oil spots. Deal with it. They are a badge of honor.
docwyte
docwyte Reader
11/17/11 3:57 p.m.
I used Simple Green and my pressure washer. Took several times to get it clean...
Nick12
Nick12 None
2/12/12 12:09 p.m.
The best way to get your oil out of your concrete is to burn it out. Seriously. One of my companies cleans driveways and garages this way. We have a local service business that performs this service for our clients. Your whole goal to getting the oil out of your concrete should be to dry it out first, then apply your acid to reduce the yellow crystallized carbon stain. If you apply acid on your oil stain without drying it out first, your just going to damage the surface of your concrete only hoping the oil stain will disappear. We apply a 5 step process to get oil out of concrete. First-clean the surface oil with a liquid degreaser, second-burn dry and evaporate the oil, third-very mild acid water mix application, fourth-very mild acid water mix application, fifth-very mild acid water mix application.
I put together some step by step videos showing this entire process that we use everyday on our clients driveway at http://howtoremoveoilfromconcrete.com/. By no means am I coming on here trying to sell my stuff to everybody. If you visit my website, you'll see that I am giving away the entire process in a written step by step guide. However, I do sell the step by step videos if you want to see the process performed rather than read about the process. Just trying to help everybody on this forum...
nicksta43
nicksta43 Reader
2/12/12 1:17 p.m.
Don't get oil on the driveway in the first place
oB9aiILHaGd9oshz1Hn1xyBd9CMWdzVaFC6NXAGyt2jpJaBjYUvscSB2tmDxpusR
