5/10/13 10:07 a.m.
You guys like weird projects. So, what would you use to power a 1957 Tornado Typhoon, our latest Classic Motorsports project?
See it here: http://classicmotorsports.net/project-cars/1957-tornado-typhoon/
Swank Force One
Swank Force One MegaDork
5/10/13 10:12 a.m.
What's the purpose of the car?
pilotbraden
pilotbraden SuperDork
5/10/13 10:15 a.m.
Rotary
ReverendDexter
ReverendDexter UberDork
5/10/13 10:17 a.m.
'busa engine
some other bike engine
cammed Ford 2.3L
12A
4A-GE
KA24
4.3 Vortec
EDIT: Buick/Rover aluminum V8
tuna55
tuna55 PowerDork
5/10/13 10:19 a.m.
I really want to say LS1...
but...
The rotary makes a lot of sense as it might be awfully crowded in there. Maybe the G13B?
mazdeuce
mazdeuce Dork
5/10/13 10:19 a.m.
Does it have to meet any racing rules? Something about that car screams supercharger to me. I'd personally like to see something four cylinder and blown. It would be really awesome to have blower whine and fairly open exhaust when you fire it up. Something with a pair of blow through side draft webbers?
fanfoy
fanfoy Reader
5/10/13 10:19 a.m.
Nothing sporty until you ditch the straight axle/drum brakes front "suspension".
I gotta go with SFO, what's the purpose of the car?
If you're not sure, I think the default answer is LS1?
bravenrace
bravenrace PowerDork
5/10/13 10:20 a.m.
Anything but an LS. I'm currently liking the straight six in my 330ci.
Storz
Storz HalfDork
5/10/13 10:22 a.m.
BMW M60
Lots of cheap donor cars out there with them, nice high end power. They make beautiful sounds
Conquest351
Conquest351 SuperDork
5/10/13 10:24 a.m.
Turbo Ford 2.3, stroked to 2.7 with an Esslinger ported aluminum head.
Maybe see if you can import a Cossie 2.3 from a Sierra or Escort from the Brits?
Boosted 2.3 DOHC from a Mazdaspeed Mazda3 bolted to a Ranger/B2300 transmission?
Swank Force One
5/10/13 10:26 a.m.
Conquest351 wrote: Boosted 2.3 DOHC from a Mazdaspeed Mazda3 bolted to a Ranger/B2300 transmission?
Hold up.
That's a thing?
Conquest351
5/10/13 10:28 a.m.
Hold up. That's a thing?
Don't see why it wouldn't work. Same engine isn't it? Ford/Mazda 2.3 DOHC? Didn't they use the same engine in the later Rangers?
Ojala
Ojala Reader
5/10/13 10:29 a.m.
In the spirit of odd and old I vote Taunus V4
Adrian_Thompson
Adrian_Thompson UltraDork
5/10/13 10:29 a.m.
Easy, if it can be made to fit without totaly destroying the car a V12 Jag engine, or if that's too wide and you want to stay a little more period correct a 3.8L Jag XK engine. Must have SU's which ever you go for. Use a decent trans though, not the Jag manuals.
ebonyandivory
ebonyandivory HalfDork
5/10/13 10:33 a.m.
In reply to ReverendDexter: I was going to say 2.0 Ford. Good suggestions!
Am other only one that reads the title and has "fat guy in a little coat" playing in his head?
mazdeuce
mazdeuce Dork
5/10/13 10:39 a.m.
The article in the last issue about the Datsun autocross car. It made something like 132hp? Can those engines be found? It would be a bit more 'vintage' if there's any desire to go that way.
Ranger50
Ranger50 PowerDork
5/10/13 10:39 a.m.
Conquest351 wrote: Turbo Ford 2.3, stroked to 2.7 with an Esslinger ported aluminum head. Boosted 2.3 DOHC from a Mazdaspeed Mazda3 bolted to a Ranger/B2300 transmission?
Why stop at 2.7L of turbocharged Lima fury??? Esslinger does make their own tall deck now, so 3.2 or 3.3L are entirely possible. Add on the ARCA head, T76, might need meth, but 1200hp is possible.
The other is OK if you can work around the DI aspect.... Or just use the Ranger version, that is conventional, and do all the Focus upgrades for power.....
ransom
ransom UltraDork
5/10/13 10:40 a.m.
Swank Force One wrote: What's the purpose of the car?
This. Also, wish I had a better notion of the scale of the car... I don't know side-valve Fords well enough to have a picture of the size of the lump that originally had residence there...
Is this thing bigger than a Berkeley? A midget? An MGB? A Cobra?
At first glance, I just think it should be a throaty four, and I like the supercharger someone mentioned.
If it's really tiny and you're feeling the call of the odd, how 'bout a BMW K100 engine? Or the 2.3 L triple out of a Triumph Rocket III? OTOH, a car that looks like this should come with heel/toe downshifts, not a sequential box...
dculberson
dculberson UltraDork
5/10/13 10:42 a.m.
The LS-based V4 mentioned in other threads?
Conquest351
5/10/13 10:43 a.m.
Why stop at 2.7L of turbocharged Lima fury??? Esslinger does make their own tall deck now, so 3.2 or 3.3L are entirely possible. Add on the ARCA head, T76, might need meth, but 1200hp is possible. The other is OK if you can work around the DI aspect.... Or just use the Ranger version, that is conventional, and do all the Focus upgrades for power.....
Didn't know they had their own blocks now. Niiiice!! I always wanted to do a Mercruiser 190 3.7L aluminum 4 cyl that's half a 460 and bolt on a turbo and A460 cyl head and go to town. Apparently they don't have typical bearings or something that would prevent them from being used in automotive projects. Don't see why the mains and cam journals can't be machined for bearings though.
Apexcarver
Apexcarver PowerDork
5/10/13 10:49 a.m.
If it can fit, chrysler firepower hemi. Keep it period correct, but hot rod it.
Pick a v8 from the era and cram it in there if it will fit it. What would a period insane hotrodder shove in it?
I would just find it kind of sad to LS-whatever such a fun and eclectic car, just a kind of bland solution. Maybe if performance was the end-all, but keeping it somewhat true to a period would give it a lot more character and spirit.
Ranger50
Ranger50 PowerDork
5/10/13 10:51 a.m.
In reply to Conquest351:
RE: Mercruiser
They have some damn thin webs for all the piston weight and crank throw to sling.... Although I have a friend running one in the local 4cyl dirt track class...... And they are trying their damnest to outlaw it.
RE: Esslinger
http://www.esslingeracing.com/Blocks.html
ransom
ransom UltraDork
5/10/13 10:55 a.m.
I'm going to double back and go with the Kent upgrade suggested as the alternative to stock in the CM introduction.
That just doesn't look like a chassis that's clamoring for big power. The Kent can presumably make enough power to be entertaining, and should make the right sorts of sounds for that body...
1988RedT2
1988RedT2 UberDork
5/10/13 10:58 a.m.
You might wanna consider upgrading those brakes, also.
Oh, and I vote Mazda rotary, preferably turbocharged to about 2 bar.
bravenrace
5/10/13 11:02 a.m.
How about this?
jfAGJBnoryIas4vixOeZFGi19uNgwAUVEv1zorQ9tPt223scoHdFe2UYZsPcXLSt
