pilotbraden
pilotbraden SuperDork
10/12/16 3:18 p.m.
I have a set of nearly new General snow tires size 205/60 r16. I also have a 2005 Focus. Does anyone know if these tires will fit? I would mount one and try it but I don't have the proper 16" wheels on hand.
JohnRW1621
JohnRW1621 MegaDork
10/12/16 3:20 p.m.
Google up the Miata. Net tire calculator and see how much size difference
drdisque
drdisque HalfDork
10/12/16 3:25 p.m.
They will definitely mount to the OE Focus 16" wheels, however they will by 1.6" taller than the OE tire size (which is pretty significant with regards to clearance) and will throw of the speedometer by 6.6% (4 mph too slow at 60 mph indicated).
jfryjfry
jfryjfry Reader
10/12/16 4:32 p.m.
If its 1.6" overall then it's about 3/4" taller on the top (.8" top and bottom each)
Hal
Hal UltraDork
10/12/16 6:37 p.m.
My 2001 Focus came with 205/50-16's stock. As others have noted your tires are a little larger in diameter which should not cause any problems other than speedometer error
BrokenYugo
BrokenYugo UltimaDork
10/12/16 7:01 p.m.
My primary concern would be whether or not they'll fit under the front spring perches on the struts.
pilotbraden
10/13/16 1:46 p.m.
In reply to BrokenYugo:
This is my concern as well.
¯\_(ツ)_/¯
¯\_(ツ)_/¯ SuperDork
10/13/16 1:51 p.m.
In reply to pilotbraden:
Can you measure that gap with whatever tires you have on there now? Should be able to get an idea of how close it will be.
pilotbraden
10/13/16 2:01 p.m.
In reply to ¯_(ツ)_/¯:
Good plan, I shall do that this weekend.
Hal
Hal UltraDork
10/13/16 2:02 p.m.
BrokenYugo wrote: My primary concern would be whether or not they'll fit under the front spring perches on the struts.
Use the RimsnTires calculator which will let you put in wheel dimensions including offsets to get an idea. I use it frequently when changing wheel widths and offsets.
WildScotsRacing
WildScotsRacing HalfDork
10/13/16 8:45 p.m.
Pretty sure it will clear the perches, a neighbor had an '02 with that same wrong tire size and it cleared fine. The extra lift will help with snow clearance, but the will hurt your torques and speedo reading; that's all I can come up with.
pilotbraden
10/14/16 9:14 a.m.
In reply to WildScotsRacing:
Excellent, the extra snow clearance will be good, torque and speedo are minor issues.
LwMMcmhMu6zrjJ3dADwsTOPmGh8oaGIrFZRbGBIURbfIERBVwRRztUIfZPC7TiWx
