Coming from a mitsubishi background, we had tons of mostly low cost options to tune the cars. You could use DSM-link, a rom based realtime datalogger with a MAF and run into the 10's in the 1/4. Some hit mid 9's running the link, and it was nice.....factory driveability, WOT tunability.
DSMlink cost $650
If you wanted to go faster, you stepped up to a stand-alone. AEM EMS was what I used. Plugged into the car, cost me $1100. Already had the wide band, and away I went. Steep learning curve, but SOOO many options.
AEM $1100
Now I"m looking at tuning options for the 318. First plans are to get a M50 in it, and then boost it. I don't think I'd be satisfied with a s50 or even s52 really, and if I'm going to boost it there isn't any point (IMHO) in paying more money for a S motor when I can run a few psi more and get the same power.
CHEAPEST option to tune that I've found is $700 +dyno time? AEM for a 3 series is $2300?
Is this country club tax or something?
I don't have the electronic background or software/hardware to tune the car, but $1000 for a car to be tuned is retarded. At most the most experienced tuners were getting $500 to fully tune an AEM...
This whole pay someone 1000 for 2-3 hours of there time is making me reconsider the M50 + boost option all together. By the time I rebuild the motor, build the turbo bits and tune it, I can buy a ls6 motor and trans, weld up some mounts and fab a set of headers, and drop it in the car.
I'm figuring:
$1000 M50 motor
$500 to freshen (lower end bearings, rings, gaskets
$1500 ish for turbo, manifold, IC....I have tons of aluminum and stainless pipe around already.
$1000 tune
$4K already, and I'm sure I'm missing a few things.
$3k will buy a LS6 w/trans complete swap, $500 custom driveshaft $200 foam dummy block to facilitate making the mounts $300 VR steering shaft $50 scrap steel plate I have laying around for the actual mounts
Heck, you could just buy a 5.3 ls1 truck engine that makes what 350hp/350ft-lbs for $1000 if you don't wanna pay up. How much more does the iron block weigh?
Goal is 400whp/400ftlbs. I don't care how I get there, but would like to have fun either way.
End thought.
