I need a borescope to get into a sparkplug hole on one of my motorcycles. Anybody have a recommendation for good/cheap/small? Has anyone used the Harbor Freight unit? The two models they sell at my local Home Despot don't have small enough lenses to fit a spark plug hole, unfortunately. For the record, I need something that will fit in a 12mm plug hole, at maximum, and ideally more like 10mm.
Hmm. Do you happen to know if they make more than one model? Because the only one I saw was resolutely big on the lens end, and won't fit in a bike plug hole.
(I edited my above post for dimensions required.)
Here ya go:
http://www.usbfever.com/index_eproduct_view.php?products_id=965
At this price, everybody should have one of these in their toolbox...
Carter
erohslc wrote: Here ya go: http://www.usbfever.com/index_eproduct_view.php?products_id=965 At this price, everybody should have one of these in their toolbox... Carter
Bookmarked. I'm getting one of those when I get paid.
In reply to erohslc:
That one has a 6cm min focal distance--that means everything less than 2.5" away will be blurry. How bad it is hard to say, but for tight spaces that will limit it significantly. For general use I'm sure it is ok, but I'm not sure you'd see scoring on cylinder walls. Blown pistons though I'm sure :)
Oh well, BTTDB (Back To The Drawing Board). Seems like the need for a cheap WebCam on a stick with a short focal distance lens shouldn't be hard to fill. Anybody with pacific rim trading experience want to start up a company?
Carter
unevolved wrote:erohslc wrote: Here ya go: http://www.usbfever.com/index_eproduct_view.php?products_id=965 At this price, everybody should have one of these in their toolbox... CarterBookmarked. I'm getting one of those when I get paid.
Secs say "Len’s Outer Diameter: 14mm " so wont fit OP's plug hole. I have one made by Rigid with a 17mm camera on the end. It does limit its use. I cant say how much it was, it was given to me with a broken elecrtical commection pin. A little safety wire as a replacement solved the problem.
Something like this? The tip is 8.2mm, and it come with a mirror (reflector tube) attachment (9.7mm dia) for looking sideways.
http://cgi.ebay.com/1-3MP-USB-digital-pen-microscope-camera-video-otoscope-/200517062461?pt=LH_DefaultDomain_0&hash=item2eafbf8f3d
The dental cameras look good, but none of them seem to specify the size of the probe.
It's a bit more $$, but gawd, those sample pictures are awesome.
Carter
