11/19/15 7:10 a.m.
Hungary Bill wrote: Newb question: Is it gas and counter-steer in a situation like that (like a drift) or is it just pitch and pray (no gas)?
No gas.
MiataMan77
MiataMan77
11/19/15 7:11 a.m.
No gas.
Would you use no gas at all or something like maintenance throttle?
11/19/15 8:03 a.m.
MiataMan77 wrote:
No gas.
For optimal "braking" it's best to use no gas at all, just put it in neutral like you're in a spin.
Tyler H
Tyler H SuperDork
11/19/15 8:06 a.m.
I bet he was praying even before he pitched. If that slide was on purpose, kudos. One trick pony: I bet he would have traded 150hp for functional brakes at that point.
bluej
bluej SuperDork
11/19/15 8:52 a.m.
he definitely was praying before he pitched it. You can hear him say oh E36 M3 when he tries the brakes on the straight, waits a heartbeat, then initiates the flick.
Knurled
Knurled MegaDork
11/19/15 11:19 a.m.
You don't use throttle to drift, you use throttle to come out of a drift.
11/20/15 7:10 a.m.
That's if you're driving a FWD car, in which case it's technically not a drift.
You definitely do use throttle while in a drift, and unless you're driving a rear-engined Porsche, lifting off the gas will help you straighten up faster.
Robbie
Robbie Dork
11/20/15 10:36 a.m.
No gas.
My bet is he was still on the brakes the whole time. When the car got a bit sideways then there is not nearly as much force for the brakes to overcome so then the wheels lock.
And for clarification, while in a drift, massive throttle application keeps the rears spinning and therefore keeps them in a low traction state. small throttle application can cause weight shift to the rear and increase rear traction.
Taking your foot off the gas 'stops' a power-induced drift because the rears spin at ground speed again and regain a massive amount of traction. Taking your foot off the gas 'starts' a trailing throttle drift because it causes a sudden weight shift to the front, reducing the rear traction.
Nick (Not-Stig) Comstock
Nick (Not-Stig) Comstock UltimaDork
11/20/15 11:10 a.m.
bluej wrote: he definitely was praying before he pitched it. You can hear him say oh E36 M3 when he tries the brakes on the straight, waits a heartbeat, then initiates the flick.
I heard the "oh E36 M3" followed by a panicked "what do I do, what do I do" before he pitched it sideways.
M2ZMMLR5ESUVDtMIkoiLt9Aaq89FjYghV5vngYNN9VZ80QFDGj6RCAV82MEF6yjh
