Woody
MegaDork
12/14/15 9:34 a.m.
There seem to be a hundred different versions of these things out there, and the general consensus seems to be that, even in the best case scenario, it is difficult to get a car moving unless all 16 wheels are pointing in the same direction before you start.
I started to think about the possibility of building a pair of large four wheeled dollies, each of which would support one end of the car.
Suggestions?
T.J.
UltimaDork
12/14/15 9:40 a.m.
Less wheels means more weight per wheel. Good caster wheels are not super cheap.
oldtin
UberDork
12/14/15 9:41 a.m.
cut down some HF furniture dollies - they're about $12/each.
I built my own using welded together unistrut and 16 industrial surplus casters. They work well. Yes it can be a challenge to get the car started going the direction you want; I just use a 2x4 as a lever under one of the dollies.
Making two big dollies might work but it would leave you with these huge things to store. Do you have a place to keep them?
I use the dollies for other things when they're not under a car - right now one is holding a motor, for example, and makes it easy to move the motor around.
We use the go jacks at work, they work damn well.
glueguy
HalfDork
12/14/15 10:01 a.m.
Woody, I would think two larger ones would have more difficulty turning or jogging the car off-axis
RedGT
Reader
12/14/15 10:13 a.m.
A few data points:
The HF furniture dolly wheels are awful for anything heavy. If you have 600 lbs on one and push it to change direction, the wheels kinda snap off. For a stack of tires or a small toolbox or something, they are great.
The HF car mover dollies with plastic wheels($59/pair) do fine, even on dirty concrete with joints and cracks, at least for a Miata-weight vehicle. 400-600 lbs/corner. At least for these wheels, changing direction is a little difficult, but they don't fall the berkeley apart when you try. I can move a Miata with 4 different direction changes (my garage SUCKS) without help. Just shove/wiggle/etc. and make sweeping direction changes when possible. Can even get it over a 1/4" lip by just lifting up on that corner and giving it a shove. I'm not particularly strong.
The car I built the dollies for was a 5000 pound ambulance/hearse. I wasn't going to stick it on a Harbor Freight dolly set that's for sure!
Go-Jacks rock! No need for a floor jack, a couple pumps lifts the tire off the ground. They roll so easily I have to chock them on a sloped garage floor. I also built special cribs that fit on top/lock in to the G-Jacks so I can have the car raised up in the air and rotate it end to end or move around the garage.
[URL=http://s240.photobucket.com/user/NOTATA/media/The%2014%20Car%20Performance%20Therapy/006_zpsfuzdrl1q.jpg.html][/URL]
UberDork
12/14/15 12:44 p.m.
I have been toying with the idea of using a skirted 12" x 12" piece of plywood with a skirt and then hook up 100 psi of air to make a car hovercraft. Would not get you far, but nice to tuck stored cars into a corner.
Kind of a GRM of this:
https://www.youtube.com/embed/uRql1fjZQf0
The go-jacks sound great but at $250/ea that's a steep barrier to entry.
I've had the HF Go-Jack knock-off's for many years and they've served me very well. Currently $99 each before you apply your choice of coupon.
In reply to Woody:
I have a set of the HF ones that I used with one of the of Europas, while the other car came with a large home-built 4-wheeled dolly(since it didn't have any rear suspension). Granted, neither of those may be the best to use for this comparison, but the large 4-wheeled dolly was much easier to move(although only 2 of the casters on it swiveled) than the 4 separate ones under each wheel.
It's all about the floor. A hard, smooth, level floor and i can roll a multi-ton jet engine on 4" steel wheels all by myself with ease.
If the floor is rough or soft the bigger the wheels need to be.
