92CelicaHalfTrac
92CelicaHalfTrac SuperDork
7/15/11 6:01 p.m.
I'm looking for a way to make a spark plug continually fire... able to be powered off a car charging system, and be flicked on and off via a switch.
I imagine something like this exists for flamethrower setups... (Which is relevant) But i don't need the extra fuel stuff. Just the "buzz box" portion.
Am i using the right term? Anyone have experience with this? Or can point to a tutorial on how to make one using modern stuff? (Ergo, no Model T parts)
Toyman01
Toyman01 SuperDork
7/15/11 6:09 p.m.
Antique ford buzz coil should fit the bill. Check E-Bay.
92CelicaHalfTrac
7/15/11 6:12 p.m.
Toyman01 wrote: Antique ford buzz coil should fit the bill. Check E-Bay.
Would those work on a 12v signal on a toggle switch?
Those things look so foreign to me, i don't even know how or what to use with it....
This is what i'm looking for? That thing makes my brain hurt.
http://cgi.ebay.com/ebaymotors/Stationary-Engine-Buzz-Coil-Ford-_W0QQcmdZViewItemQQhashZitem3a6815da8dQQitemZ250854365837QQptZVintageQ5fCarQ5fTruckQ5fPartsQ5fAccessories
92CelicaHalfTrac
7/15/11 6:21 p.m.
May have found a decent tutorial on youtube...
http://www.youtube.com/watch?v=kqTCMKJa77s
http://youtu.be/HfqM2CXC4gw
Dr. Hess
Dr. Hess SuperDork
7/15/11 8:20 p.m.
Lots of ways to do that. How simple or complicated do you want to go? You basically just need an ignition coil, some points, a capacitor across the points, something to trigger the points like a little cam on a little electric motor and 12V. Or use a relay and a 555 timer, which you could control with your switch. Google up 555 timer relay circuit. Everything except the ignition coil is at crap shack.
Taiden
Taiden HalfDork
7/15/11 9:31 p.m.
My thoughts were solid state relay and a 555 timer
geomiata
geomiata Reader
7/15/11 9:52 p.m.
all i want to know is why?
Raze
Raze Dork
7/15/11 9:59 p.m.
In gradschool I needed to create a continuous arc though a self made spark plug (titanium rod through a ceramic sleeve into an aluminum supersonic windtunnel. I recall using a HUGE Accel or MSD high frequency ignition coil, the coil was square but about 3 times larger than a stock coil in any car. we hooked it to a high frequency generator and essentially had it firing at max frequency which was so fast, it really never 'stopped' for all intents and purposes...
92CelicaHalfTrac
7/16/11 9:40 a.m.
geomiata wrote: all i want to know is why?
For shenanigans. My car runs rich enough between shifts that it will on occasion blow some pretty big fireballs.
I'd like to be able to make it blow fireballs EVERY shift if i do so desire.
Yeah, it's juvenile and stupid. But.... FIRE!!!! OUT OF MY CAR!!!!
No flamethrower kit required.
mtownneon
mtownneon New Reader
7/16/11 9:44 a.m.
92CelicaHalfTrac
7/16/11 9:46 a.m.
mtownneon wrote:
LOL Dave!!
mtownneon
7/16/11 9:53 a.m.
I swear Ben, if you want to set the MX-Fail on fire, bring it by the house and I'll fire up the torches.....
92CelicaHalfTrac
7/16/11 9:55 a.m.
It's been on fire before... on the way to your place, actually.
Taiden
Taiden HalfDork
7/16/11 2:02 p.m.
I endorse this product and/or service.
CfmAjdnv0WAAZlgqUGVCbpTWqih1QmFpVeOpTxSJXftGJ7wLLsxFvvPX9RQwW6Fb
