oldtin
oldtin UberDork
7/9/14 3:04 p.m.
2000 lb car - need to fab cage foot plates and pick up points for lower front a-arms. Is 1/8" enough or go to 3/16"? Cage is a little overkill 1 5/8 x .120 (could have gone .095)
Leafy
Leafy Reader
7/9/14 3:09 p.m.
JohnyHachi6
JohnyHachi6 Dork
7/9/14 3:25 p.m.
You should go based on the rollcage rules for whatever series you're going to be racing in (or thicker if you feel that's not sufficient). I used 1/8" on my last cage because I had relatively small footprint for the spreader plates and the front downtubes were on the floor (though tied in to the sills). Here are the requirements for a few organizations I know:
Chumpcar: 0.125" (floor mounted)
NASA: 0.080"
SCCA: 0.080" to 0.25"
Don't forget to check on the total footprint area required (or sometimes it's minimum length of any single side of the plate).
oldtin
oldtin UberDork
7/9/14 3:43 p.m.
The rules are a little sketchy for vintage racers when it comes to roll bars - 1967 scca gcr, but encouraged to go with more modern standards. I see a bit of everything in the paddocks. I think I'm ok on the base plates with 24 sq inches & 1/8". Feel like the suspension mounts may need to be a little beefier with some grippy tires.
ncjay
ncjay Dork
7/9/14 4:04 p.m.
NHRA rule book calls for 1/8" thick plates. Sometimes I might use 3/16", but it's usually overkill. When cage work is involved, it's never a bad thing to go above and beyond the minimum.
tr8todd
tr8todd HalfDork
7/9/14 5:32 p.m.
2000# car? In some classes you can go 1.5X.095. Check the rule book and go as small as possible. Allows for tighter bends and more clearance for you.
Kenny_McCormic
Kenny_McCormic PowerDork
7/9/14 5:43 p.m.
1/8 will be plenty. Tied into a floor pan, 3/16 might actually be weaker, more liable to punch straight through the floor like a punch than deform with it as 1/8 or 0.80 would. Note how SCCA has an upper limit, that's why.
fanfoy
fanfoy HalfDork
7/9/14 8:59 p.m.
Kenny_McCormic wrote: 1/8 will be plenty. Tied into a floor pan, 3/16 might actually be weaker, more liable to punch straight through the floor like a punch than deform with it as 1/8 or 0.80 would. Note how SCCA has an upper limit, that's why.
this.
pHoIj4gwm0vreqi2AsrH3xyk835sCClDEs09WSyJMh4C2ar7iviPxP1r8KH4ABzf
