DILYSI Dave
DILYSI Dave MegaDork
6/5/12 7:48 a.m.
I'm not seeing a welded together car. What it looks like to me is that the floor split at a seam. I suspect that the construction has the horizontal floor meeting a vertical section right there under the front of the rear seat, and the two panels are spot welded together - common construction for a Honda. Not really structural either. The only structure that had to fail in this case was the rocker box, and the boxed section at the C-Pillar / Roof juncture. The roof didn't tear - it failed across the top of the rear window.
I just see it as the right hit at the right speed and this is the inevitable result.
bearmtnmartin
bearmtnmartin Reader
6/5/12 9:03 a.m.
Pickup trucks are no better.
http://afriktube.com/view/891/fail-tow-truck-breaks-pickup-truck-in-half/
dean1484
dean1484 UltraDork
6/5/12 10:25 a.m.
I thought that trucks had solid frames? I am betting that was damaged pre them pulling it out. Thinking more about it I am betting it was completely staged. AND why would you go to all the trouble to hook it to the part that is way out in the watter? I call fake / staged. If you were trying to pull it out wouldn't you drag it out from the back and then roll it over?
OR
It is all the result of the liberal application of Beer.
bearmtnmartin
6/5/12 10:52 a.m.
In reply to dean1484:
That one for sure.
Knurled
Knurled Dork
6/5/12 1:04 p.m.
bearmtnmartin wrote: Pickup trucks are no better. http://afriktube.com/view/891/fail-tow-truck-breaks-pickup-truck-in-half/
Look, they trained a Toyota to do sit-ups!
dean1484
dean1484 UltraDork
6/5/12 1:20 p.m.
I could have sworn it said GMC on the grill
vqSgE5P4z3sXHEpsQWbxPyZzejyh6Acs2dOtHCvn4KfKmg0YFyUveQl6fbKzQ3oK
