Tk8398
Tk8398 Reader
1/17/19 12:54 a.m.
I have a bug with a single port 1600, which isn't currently drivable due to carb issues.  I have the stock intake, aircleaner, and related parts, but the carb has failed beyond repair (massive leak), and a complete Weber ICT kit that is currently installed but sticks so bad the car isn't drivable.  I have been fighting with the ICT kit pretty much since I put it on, and at this point the best thing to do with it would be to remove it and make it into as many small pieces as possible with a large hammer.  Other than maybe the intake manifolds, none of that is really usable either.  So, its to the point of either selling the car as a project that needs to be towed, or try something completely different to make it a usable car.  Does anyone have any recommendations?
bludroptop
bludroptop UltraDork
1/17/19 4:30 a.m.
Buy a brand-spanking new 34 Pict-3 carb for ~$100?  (shrug)
californiamilleghia
californiamilleghia Reader
1/17/19 6:05 a.m.
A single port motor needs a 30 pict carb ,  or now often sold as a 30/31 pict ,
The 34 pict has a larger base and will not bolt on a single port manifold without an adapter ,
Not sure where you are but the best car is a 1967 carb which does not have any smog stuff..,..
Check on thesamba.com and see what they say about carbs available new now.....
Empi carbs made in China had a lot of problems , check to see if they are fixed yet....
MG3zLLNYbgOf2XSahHa4xYHNMzMz8fazoRW1b8ZRAlKz8l3fnM1ISrTjiKq7JC2W
