old_
old_ New Reader
10/26/12 1:59 p.m.
I scored a good deal on some snow tires for my wife's scion xA. I'm looking for a spare set of wheels to mount the snows on. I need some 15" 4x100's with a FWD offset. I know some late model civics, miatas, corollas, and scions came with this combo but the junk yards seem to think everything from those cars is made of gold. Does anyone know of any other cars that I can look to get these wheels from? I don't care if they are alloy or steel.
thanks a lot!
fidelity101
fidelity101 Reader
10/26/12 2:00 p.m.
BMW E30s Miata Civic early sentra too I think
oh my mazda2 has that size :)
also, saturn SC/SL2s
Adrian_Thompson
Adrian_Thompson SuperDork
10/26/12 2:04 p.m.
Protoge, Escort, ZX2, some Rx7's
rob_lewis
rob_lewis Dork
10/26/12 2:07 p.m.
Look for MINI wheels. I bet your local Craig's will scare up a bunch. Upgrading MINI rims are a very common.
-Rob
friedgreencorrado
friedgreencorrado PowerDork
10/26/12 2:12 p.m.
Later VWs (2000-up IIRC) have them. Almost universally alloys, though.
44Dwarf
44Dwarf SuperDork
10/26/12 2:17 p.m.
Good luck finding a set but 92 Geo Storm GSI had 15 inch alloys in 4x100 bolt pattern and took 205x50x15 tires
old_
old_ New Reader
10/26/12 2:20 p.m.
thanks a lot everyone... I'm craigslisting this stuff now.
keep 'em coming if you think of any others.
Derick Freese
Derick Freese SuperDork
10/26/12 2:25 p.m.
Congrats, you've found the most common wheel size ever. You have about a 50/50 chance that any given wheel on Craigslist is a 4x100. About half of those will be of the 15" variety.
mw
mw Dork
10/26/12 2:30 p.m.
No rx7's were 4x100. Also vw's 98 and earlier were 4x100 (golfs and jettas non vr6). Integras were that bolt pattern.
Matthew Huizing
Matthew Huizing Reader
10/26/12 2:32 p.m.
Tire Rack is listing 14" winter packages for xAs.
'92-'93 Storm GSi/Impulse XS/Stylus XS/RS 15x6 40mm offset 56.5mm hub.
DOHC Sx2 Saturns 15x6 50mm offset 57mm hub.
BMW E30 325ix 15x7 57mm hub.
BMW E30 14x6 35mm offset 57mm hub
BMW 325is/es 14x6.5
Honda/MINI hub is 56.1 mm.
Integra GS-R 15x6
Various '95-'02 Miata (M) 15x6 40/45mm offset 54mm hub.
The standard base model wheels on all these are 14".
10/26/12 2:44 p.m.
You do have to watch the hub size - the Miata ones are pretty small, so it can be hard to fit Miata wheels on a lot of other cars.
I think there was a first generation RX7 with that pattern - GSL-SE? Not that it's liable to be a factor.
ValuePack
ValuePack Dork
10/26/12 2:46 p.m.
Sentra thru at least B14. Was B15 the switch to 4x114.3?
fidelity101
fidelity101 Reader
10/26/12 2:47 p.m.
Keith Tanner wrote: You do have to watch the hub size - the Miata ones are pretty small, so it can be hard to fit Miata wheels on a lot of other cars. I think there was a first generation RX7 with that pattern - GSL-SE? Not that it's liable to be a factor.
the GSLSE were 4x114.3 the non GSLSE were 4x100
and yeah I had to buy hubcentric rings to fit E30 wheels on my mazda2
ValuePack wrote: Sentra thru at least B14. Was B15 the switch to 4x114.3?
Yes because I remember having SE-R Vspec wheels on my old s13 way back in the day.
oldeskewltoy
oldeskewltoy Dork
10/26/12 2:50 p.m.
Look for late 90s early 2000 Civic wheels. I bought a set a few years ago and they fit my All-Trac perfectly.... they came with Hakapelittas
ebonyandivory
ebonyandivory Reader
10/26/12 3:07 p.m.
http://forums.beyond.ca/showthread/t-117406.html
A bit long but...
mw
mw Dork
10/26/12 3:11 p.m.
fidelity101 wrote: the GSLSE were 4x114.3 the non GSLSE were 4x100
Nope. Gslse was 4x114.3, but all other first gens were 4x110mm.
Your scion uses a 54.1mm hub bore which is the smallest available, so as long as you don't mind being non hub centric, your hubs will fit in the bore of whatever wheels you buy. If you do want Hubcentric, stick with wheels from Mazda, ford, and Toyota.
One other thing to remember is brake clearance. Try one on to make sure the calipers don't hit the back side of the wheel. You can always run spacers, but it's nicer no to have to.
10/26/12 3:26 p.m.
We've got an FB rear end in the shop that I'm sure is a 4x100. I'll have to check it out.
mw
mw Dork
10/26/12 3:32 p.m.
As far as I know all usdm rx7 rears were either 4x110/114.3
EvanB
EvanB PowerDork
10/26/12 3:35 p.m.
Yes, all FBs are 4x110 or 4x114.3.
93EXCivic
93EXCivic MegaDork
10/26/12 3:36 p.m.
rob_lewis wrote: Look for MINI wheels. I bet your local Craig's will scare up a bunch. Upgrading MINI rims are a very common. -Rob
What is the offset on the MINI wheels? I am also looking for 15" for the Civic since the tire supply for 14" wheels sucks....
DrBoost
DrBoost PowerDork
10/26/12 3:37 p.m.
According to logdog, there are no 15" wheels with a 4X100 pattern. He kept trying to push 16's, 4X110's and motorcycle wheels when I was asking him to find some for me.
old_
old_ New Reader
10/26/12 3:46 p.m.
45mm offset for the 15's. 5.5" width. should fit fine on a civic. you will have to get some conical shaped lugs as the civic uses rounded/ball style lugs.
Irish1
Irish1 New Reader
10/26/12 3:56 p.m.
Baloney. The 88-91 BMW E30 325iX AWD coupes and sedans used a 15X7 4X100 BMW/BBS Euroweave with a 41 mm offset and a 57.1 hub center. Lots of the E30 boys are using these with 15 mm adaptors in lieu of the expensive 15X7 Euroweaves. Great wheels, light and strong. Occasionally you'll run across a 325iX with steelies in the same offsets in a junkyard, but most were up-optioned with the BBS wheels. Craigslist Seattle and the PNW and you'll find some.
DrBoost wrote: According to logdog, there are no 15" wheels with a 4X100 pattern. He kept trying to push 16's, 4X110's and motorcycle wheels when I was asking him to find some for me.
JohnRW1621
JohnRW1621 PowerDork
10/26/12 4:03 p.m.
There are many guides like this on the internet.
http://www.roadkillcustoms.com/hot-rods-rat-rods/Wheel-Bolt-Pattern-Cross-Reference-Database.asp?LugCount=5&StudSpreadInch=4.75&StudSpreadMM
http://www.performancewheeladapters.com/servlet/the-template/guide/Page
Be mindful of bolt size and center bore.
In your case, Miata 15" rims and Mazda MX3 15" rims should be perfect fits if you are willing to go alloy.
Escort ZX2, '97 and newer are the proper center bore too.
Base model Chevy Cobalt steel rims will work but you should get hub spacers to fill the center bore gap (the Cobalt has a larger hole.)
DrBoost
DrBoost PowerDork
10/26/12 6:58 p.m.
Irish1 wrote: Baloney. The 88-91 BMW E30 325iX AWD coupes and sedans used a 15X7 4X100 BMW/BBS Euroweave with a 41 mm offset and a 57.1 hub center. Lots of the E30 boys are using these with 15 mm adaptors in lieu of the expensive 15X7 Euroweaves. Great wheels, light and strong. Occasionally you'll run across a 325iX with steelies in the same offsets in a junkyard, but most were up-optioned with the BBS wheels. Craigslist Seattle and the PNW and you'll find some.
He'll read this and realize how wrong he was. Thanks.
X0NUWmaIzgjhmFrz1PFJFIBBdYHaBsyQXdmtjVlwgRcNdEIiEV4uoObqZljptLsS
