noddaz
noddaz SuperDork
7/12/19 12:21 p.m.
The answer would be Miata, wouldn't it.
Just pondering.  No one get excited.
Yet.
buzzboy
buzzboy HalfDork
7/12/19 1:18 p.m.
Are you buying the adapter? I found an adapter from J series engines to nissan Z33/Z34 transmissions. The only other commonly found adapter I've seen is to a Miata transmission.
RacetruckRon
RacetruckRon HalfDork
7/12/19 1:28 p.m.
If you are making your own adapter KA, RX8, 300zx and T5 are probably going to be the easiest to find cheap manual transmissions besides the Miata options.  The Z33/Z34 trans are starting to get hard to find and pricey around me at least.
TurnerX19
TurnerX19 HalfDork
7/12/19 5:45 p.m.
What is an 01CL??
noddaz
noddaz SuperDork
7/12/19 6:05 p.m.
TurnerX19 said:
What is an 01CL??
Sorry, 2001 Acura CL V6 engine.
_
_ HalfDork
7/12/19 10:23 p.m.
Whatever you do, don’t go w58. It is somewhat strong, has a Decent gear ratio set, but is the clunkiest transmission I’ve ever rowed.
Ranger50
Ranger50 UltimaDork
7/12/19 10:29 p.m.
There was a QuickTime bellhousing in the Holley clearance page for Honda v6’s...
Knurled.
Knurled. MegaDork
7/13/19 5:31 a.m.
Must be a local thing.  When you could find them, V8 T5s were $800-900, but they've all dried up.
I think you can still get new ones for $1200ish.  There's no point in going with a 4 cylinder T5, the ratios are garbage and they technically aren't strong enough for a V6.
NordicSaab
NordicSaab Dork
7/13/19 6:38 a.m.
Saginaw 4 speed?
Wqz5MVTzxpTewCy7fhhTZxHulwVxUpopVLg1o8g07zB9TJWlTiKymYwpgmKxgXAq
