Wally (Forum Supporter)
11/9/23 12:25 p.m.
The Corvette sat a while and the battery has gone dead. Putting my charger on it doesn't seem to do anything. Do I need a different charger or is there something I need to be doing?
codrus (Forum Supporter)
11/9/23 12:34 p.m.
Many "smart" chargers will not charge an AGM battery that has gone too low, something about the resistance properties of it makes them think that it is a battery with a shorted cell and they shut down for safety reasons.  You can sometimes get around this by hooking up another battery in parallel with the AGM.
See "how to resuscitate a deeply discharged battery" here:  https://www.optimabatteries.com/charging
Aaron_King
Aaron_King UltimaDork
11/9/23 12:40 p.m.
I ended up buying a modern charger for my AGM.
Indy - Guy
Indy - Guy UltimaDork
11/9/23 12:53 p.m.
In reply to codrus (Forum Supporter) :
Prius cars run an AGM 12 volt battery.  Those are my only experience, but I buy Priuii cheap and they usually have dead 12V AGM batteries.
I've always been successful in bringing them back to life using this method:
  • Battery out of car
  • With a pair of jumper cables connect AGM battery to a (known) good regular Lead/acid battery
  • Leave the two connected for about 24 hours
  • Disconnect the two batteries
  • Put your charger on the Lead/acid battery change that one up again
  • Connect the two batteries together with jumper cables again (+ to +, - to -) and connect battery charger to the AGM battery .
  • Let charge for 24 hours.
Good to go again, note some really flat batteries have required the above procedure to be performed multiple times.  But I have a 100% success rate on the last 8 batteries I've done this to.
Edit to add:  The AGM battery usually gets "hot" while charging.    The first one I did, I was very concerned, but that appears to be normal for these.   I just use a simple charger.  I'll take a picture of it and add later tonight.
11/9/23 2:19 p.m.
In reply to Indy - Guy :
I've done something similar, but simpler.  I just put the spare lead acid battery on the floor and connected it to the charger, then ran jumpers from the LA to the AGM in the car.  I did leave the hood open, but I didn't notice any real heat buildup.
Both batteries were fully charged in about 3 days or so.
eastpark
eastpark HalfDork
11/9/23 8:36 p.m.
+ 1 to what Duke wrote. I did the same and it worked fine.
11/9/23 8:42 p.m.
2+...I've been successful doing this too.
ClearWaterMS
ClearWaterMS Reader
11/10/23 1:45 p.m.
the newest CTEK charger that i purchased had an "AGM" mode and i put the charger into AGM mode and leave it plugged into the cigarette lighter on my car which has an AGM battery and it works fine.
https://www.amazon.com/CTEK-40-206-5-0-12-Battery-Charger/dp/B00CD44RQO/ref=asc_df_B00CD44RQO/?tag=hyprod-20&linkCode=df0&hvadid=312844081654&hvpos=&hvnetw=g&hvrand=12144841581412696668&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9021527&hvtargid=pla-461267516060&psc=1
11/10/23 2:28 p.m.
In reply to ClearWaterMS :
When I first read your post all I could picture was that meme sketch of the V8 with the exhaust routed directly into the intake.
Of course, I can't find the image when I need it.
johndej
johndej SuperDork
11/10/23 2:38 p.m.
I'll have to try that, know how long you should expect that to work? Just replaced my Miata battery which was 6 years old after trickle charger didn't bring it back.
mtn
mtn MegaDork
11/10/23 2:44 p.m.
I've done it by the method described above. Connect it to a known good battery, connect charger to the good battery. 1-12 hours later, It is good to go.
californiamilleghia
californiamilleghia UberDork
11/10/23 6:32 p.m.
How long can a AGM battery be dead and still bring it back to enough to start a car ?
I sometimes see used dead ones at repair shops that I can get for a couple 6 packs :)
mtn
mtn MegaDork
11/10/23 8:52 p.m.
The one that was 6 years old and dead for an entire winter lasted about 6 more months. I revived it again after it sat for 2 weeks, it lasted 2 more weeks then had to be kept on a trickle charger for anything longer than 36ish hours. I sold the car advertised with a known dead battery at that point.
H3TzIZUDbXZbsz4C5flOGOULMyQuLv1kthxlsd3ExQASIcZEOMI8HgS9eFS6ELA9
