singleslammer
singleslammer UberDork
9/6/16 8:20 a.m.
So I just got this:
as seen here.
I am trying to see if there is a way to do a really air bag suspension, at least on the rear. My thoughts are air bags ($80 a piece) with schrader valves or something similarly cheap, and 120v 8 gallon air tank (I already have this) in the bed. I would like to make if somewhat slick so I am not opening valves on each bag individually.
I only have a basic understanding of what I just said. I am fully capable of mounting the bags and there is plenty of info on how to do this correctly. I am a little lost on fulling the bags/draining them.
stafford1500
stafford1500 Reader
9/6/16 8:32 a.m.
for grm style look into 12v irrigation control valves. one for fill one for release on each bag, but tied together so both fill or release at the same time (more or less). I know they will hold at least 90psi or so. You may want to add small diameter bleed jets so it doesn't drop from full up to full down too quickly.
xflowgolf
xflowgolf Dork
9/6/16 8:51 a.m.
The dirt cheapest way to do this is to just T the rear air line together. Use push to connect plastic DOT airbrake line connectors and plastic line. It's easiest to cut and get a good seal if you use one of those razor blade cutter pliers. Then you can put two ball valves on the T (or remotely mounted on a line from the T so you can control from in cab/etc.).
One ball valve dumps to atmosphere to lower. The "fill" ball valve connects to your tank to raise.
Are you trying to do front and back? or just rear.
STM317
STM317 HalfDork
9/6/16 9:00 a.m.
What style suspension would this be? 4 link/ bag on bar?
iceracer
iceracer PowerDork
9/6/16 9:08 a.m.
I had air bags on my KJ for supplemental support when towing.
The lines were "Td" and connected to a single Schrader valve which I mounted by the electric plug.
A remote hook up as suggested above would work. Depends on what you want to do.
singleslammer
9/6/16 9:25 a.m.
I might start in the rear to get a fell for it.
Those irrigation valves are awesome! 116 PSI for $7 Adafruit
singleslammer
9/6/16 9:27 a.m.
This is a '72 but the suspension should be the same.
wearymicrobe
wearymicrobe UltraDork
9/6/16 10:07 a.m.
singleslammer wrote: I might start in the rear to get a fell for it. Those irrigation valves are awesome! 116 PSI for $7 Adafruit
  1. sharing air between bags is not the best thing in the world for handling or making it down the road safely.
  2. Your bags will pressure way over 116 PSI when taking a hit.
  3. Your front bags on a air of that weight are going to need 140+ psi to keep it in the air if it has a big block or even a fully dressed small block
  4. York compressor from the junkyard for cheap and best way to generate the air. Fittings and 3/8ths lines are gong to cost you at least 200$ to get the air back to the tank but you would need three vairs pumps to get a tank that large filled properly and they are going to blow.
singleslammer
9/6/16 10:20 a.m.
Definitely not sharing lines for bags
Here is one that actually claims to be air ride capable with a 150 psi max. Mot saying it isn't a giant POS though
c8jQg8dv0Jye0iWz4ZyVUpFzEAEwoC3Bdz1kCOax40LNzt00MYcGyIo0SUrx47jg
