DustoffDave
DustoffDave Reader
2/21/11 2:38 p.m.
Is there one, or am I going to have to just use the paint-stripper attachment for my drill?
44Dwarf
44Dwarf Dork
2/21/11 3:15 p.m.
Propane torch on the opposite side (the metal side) when you here it pop jam the screw drive in the bondo and pop it off the rest of the way.
spitfirebill
spitfirebill SuperDork
2/21/11 3:32 p.m.
^^^^ yup.
DustoffDave
DustoffDave Reader
2/21/11 6:06 p.m.
I guess I should have given more background -- it's on the outside of a motorcycle gas tank, so the torch method may prove difficult. Can I heat around the area, will there be enough heat transfer underneath the filler, or will it just melt the tank sealer on the inside first?
44Dwarf
44Dwarf Dork
2/21/11 7:35 p.m.
You'll likley melt the linner, so in that case i'd toss the tank in an Electrolosis tank and remove both paint, bondo and liner then start from scratch.
motomoron
motomoron HalfDork
2/21/11 9:01 p.m.
4" angle grinder and an 80 grit flap wheel - and be careful, MC tanks, particularly newer ones are very thin.
ATNlUEnoCfyT0ZtrXZ0Q3Soqvb8jSW30Lq9fT5kGTS13jGkHcj4Z8YyzRUnHlohL
