96DXCivic
96DXCivic New Reader
10/2/08 12:37 p.m.
My Civic DX does not have a tach. How hard is it add one? Also does the D16Y7 engine have a rev limiter? And I am looking at buying some stock steelies to mount tires to autocross on but the stock size is 185/60-14 and there are no sticky tires available for that size that I saw. What size can I fit?
Type Q
Type Q Reader
10/2/08 1:24 p.m.
96DXCivic wrote: My Civic DX does not have a tach. How hard is it add one? Also does the D16Y7 engine have a rev limiter? And I am looking at buying some stock steelies to mount tires to autocross on but the stock size is 185/60-14 and there are no sticky tires available for that size that I saw. What size can I fit?
The questions I can answer for you questions are:
The engine has a rev limiter
What to you mean by sticky tires? There used to be a number of R compound tires available for 14' wheels. I have bought 185/55/14 and 195/55/14 Kumho v700's and put them on 14x5 steelies for my Civic. 195/60/14 can also work.
96DXCivic
10/2/08 1:57 p.m.
I am thinking 195/60-15 Hankook Ventus R-S2.
Shoden
Shoden
10/2/08 1:59 p.m.
185/60-14 are what my CRX runs stock, and I'm using Falken Azenis RT-615s in 195/60-14. I used to run R compounds on 13x8 wheels, but I got tired of switching wheels at the track, and I've been really happy with the Azenis.
autolex84
autolex84 New Reader
10/2/08 2:10 p.m.
96DXCivic wrote: I am thinking 195/60-15 Hankook Ventus R-S2.
do you mean 195/60/14? cause you would have to buy new wheels then, and if you are going to buy new wheels, you might want to think about getting a 15x7" wheel and doing a 205/50/15 or a 195/50/15 Bridgestone RE-01R
96DXCivic
10/2/08 2:12 p.m.
Yup I meant 14" sorry
autolex84
10/2/08 2:50 p.m.
195/60/14 Falken RT-615 or Hankook Ventus RS-2 is probably the way to go if you want to stay in street tire class.
Also, instead of a tach, you can JUST install a shift light (which reads engine rpm and turns on at a preset RPM) and you can set it to whatever. (just an idea).
96DXCivic
10/2/08 2:54 p.m.
It will probably be run in ST for at least a while until in get a bit more money at which time it is going to be in FSP. Where exactly would the shift light/ tach plug-in into the ECU right?
autolex84
10/2/08 3:33 p.m.
usually has a pulse sense. comes off the coil/distributor?
ignorant
ignorant SuperDork
10/2/08 4:04 p.m.
get an ex or lx gage cluster with a tach.. put in car It works!!!!
ArtOfRuin
ArtOfRuin Reader
10/2/08 4:12 p.m.
http://www.superhonda.com/forum/f94/diy-gauge-cluster-swap-92-95-civic-w-pics-56k-420kb-274853/
You can yank a tach-equipped instrument panel from another car and swap it in. The above link gives instructions on how to do it.
DILYSI Dave
DILYSI Dave SuperDork
10/2/08 5:13 p.m.
You don't need a tach for autox. Generally the course will define your 1-2 shift, and then you just leave it there. You never look at the tach while running.
iceracer
iceracer Reader
10/2/08 6:18 p.m.
I looked at the tach once and went off course.
96DXCivic
10/2/08 6:40 p.m.
Well I also kinda want it for street driving.
OVu49EICKKf3E2UAANwxE7xoCjB5Nly9cBeKzfDcahWz9zHluYgBqxplF8wsdls2
