93EXCivic
93EXCivic MegaDork
11/12/13 2:48 p.m.
So I was putting new shocks on the Civic and broke the lower bolts. After I lot of running around looking for a M10x1.25 90mm long bolt, I ordered some from McMaster but they got in and I realized they are Class 8.8. I can't find these bolts locally at all. Am I screwed or can I use class 8.8s for that?
93EXCivic
93EXCivic MegaDork
11/12/13 3:10 p.m.
Or I found 100mm class 10.9 long bolts and I could stack 3 class 10.9 washers. Or I could use an 80mm class 10.9 but that would leave threads in the bushing...
Streetwiseguy
Streetwiseguy UberDork
11/12/13 3:24 p.m.
I wouldn't be horrified to use the 8.8's. The 80's are too short.
93EXCivic
93EXCivic MegaDork
11/12/13 3:34 p.m.
The shock bolts were just marked 10 not 10.9 so I have no idea if they were 10.9 or if that was just some marking Honda used.
novaderrik
novaderrik PowerDork
11/12/13 6:09 p.m.
they will work fine for shock bolts.
Kenny_McCormic
Kenny_McCormic UltraDork
11/12/13 7:01 p.m.
Typical OE suspension bolts are 8.8, why are you concerned about it, taking it off some sweet jumps? That's a shear strength around 8000lbs for a M10, in single shear, almost double that for double shear. Should be adequate for a shock absorber on a 1800lb car.
Jaxmadine
Jaxmadine HalfDork
11/12/13 7:30 p.m.
Cant order from honda?
11/13/13 5:51 a.m.
8.8 bolts are tested to 640 MPa (megapascals) or 92,800 ft. lbs.
What's this Honda weigh anyway?
http://www.boltdepot.com/fastener-information/Materials-and-Grades/Bolt-Grade-Chart.aspx
r4uBRgK5YPCHKeqVPlCC8YSOmft57zfWsYbSGAoiOUecnsGHIwUxrrDeiLrFDjpA
