flexi
Reader
9/24/16 2:48 p.m.
Any tips to remove RTV from surfaces and inside threads? Attempting to seal up the bottom end of a miata block. (RMS, oil pump, oil pan, etc.) Is there a solvent that works? Reluctant to use HF taps since they don't seem to use the same standards as everyone else.
besides a good tap, a rifle bore brush, compressed air and brake clean or all of the above.
flexi
Reader
9/24/16 3:33 p.m.
Good idea on the bore brush! Wasn't sure what solvent would work. I'll try the brake kleen, and the bore brush. Thanks.
44Dwarf
UltraDork
9/24/16 8:45 p.m.
mineral spirits will soften and swell RTV. then a rifle bush will clean the hole.
I use a thread chaser and air gun. Don't use a tap; its a different animal. It will cut more metal. Just use a chaser.
Razor blade to get the thick stuff, kerosene or carb cleaner and a wire brush to get the major bits off of the sealing surfaces and carb cleaner and a Scotch-Brite pad to get it really clean and carb or brake cleaner on a paper towel to get it clean enough to seal.
I never really worry about the threads.
Cured RTV silicone isn't actually dissolved by much. Maybe methylene chloride, Permatex and Loctite both sell Silicone solvents, but they're way toxic and expensive.
I use a variety of scrapers, steel and brass scratch brushes, and chasers. I find the stiffer, straighter and sharper the scraper, the less likely it is to put scratches in the sealing surface. So I keep a high speed steel lathe cut-off blade around. It works great.
![](http://www.tormach.com/uploads/images/Gallery/products/lathe_products/Lathe-Cutting-Tools/35145_T_type_cut_off_blade_1_8x11_16x5_HSS_M2.jpg)
Yah, dissolving the sealant isn't the goal so much as separating it from the metal. This is aided by a solvent and mechanical removal (scrapers/wire brushes/Scotch-Brite pads, the ones you hold in your hand not the Rolocs!)
