RossD
RossD MegaDork
4/26/20 6:39 a.m.
Cleetus McFarland's latest video of his C6 corvette with a new 427cid with a massive turbo, they talk about hearing the two step while drag racing. I am assuming its a tuning thing.
What is this "two step"?
https://youtu.be/_cWvHojLX0A
newrider3
newrider3 New Reader
4/26/20 7:03 a.m.
RossD
RossD MegaDork
4/26/20 7:26 a.m.
So you want a rev limiter closer to the lockup speed of the torque converter? I suppose you dont want to have to wait for the engine to slow back down for the torque converter to catch back up...
CrustyRedXpress (Forum Supporter)
CrustyRedXpress (Forum Supporter) Reader
4/26/20 8:36 a.m.
The chip burner program that I used for my CRX challenge car had a two step option so I used it in the drags. Somebody explained it to me that for a good launch everything has to happen at the right time, for the right amount of time. Being able to hold the RPM stable is one less variable to deal with-it also makes adjusting that variable much easier. Want to try launching at 3600 rpm instead of 3500? No problem. It allows you to concentrate on other parts of the launch like clutch engagement.
Run_Away (Wears Clogs)
Run_Away (Wears Clogs) Dork
4/26/20 8:59 a.m.
It's more than a rev limiter on turbo cars, it also adds fuel and retards timing so combustion happens in the exhaust system. This spools the turbo. That's why they blew up the accordion flex section on the crossover pipe
6kymGmLed7EgYdOqeZTnf5K3P4ffdDbEZBkbsUcLXZhhepRcIrlf2BCdAYrXRllY
