Foxworx
Foxworx Reader
7/19/19 2:35 p.m.
Hello All,
At the shop where I work we have an Ingersoll compressor.  I am in the process of adding a fan cooled aftercooler and moisture seperator.
I have the aftercooler mostly plumbed but unfortunately I'm stuck right now.
The connection between the pump and the tank on the compressor is 5/8 copper with inverted flare fittings (7/8-18) on each end (male)  I have looked high and low for a 7/8-18 (Inverted flare-male) to 1/2" npt (or similar) with no luck.
Right now I'm thinking I might need to buy a flare kit and split this copper in half and add the male fitting which I can get adapter for.
Or
Split the copper and solder/sweat a NPT adapter on each half
Or.
Do the same with compression fittings.
Thoughts?
Cheers,
Fox
TurnerX19
TurnerX19 HalfDork
7/19/19 4:01 p.m.
Get the shop to buy the flare tool. Master Cool brand is my preference. If the boss wont pony up for the tool I would solder/sweat, which won't take much extra heat today!
WonkoTheSane
WonkoTheSane SuperDork
7/19/19 7:51 p.m.
Sure it's not a metric thread?  22mm is .876 vs 7/8's .875.    I think you'd need a 22 x 1.5 to be equivalent, maybe you can find that locally?  Isn't that an o2 sensor thread pitch?
BxNHGgZKBbYzQGsmOTJnxOZp590EWVYs28zYz1xCS0ujH8YPodqUW8UvzOxOKpLf
