For the transmission swap in my ae86 I’m needing a clutch that’s the stock diameter but has a ford center spline. Is there a company that can make that happen for not cubic dollars?
Streetwiseguy said:Can't find a clutch from a Ford with the correct outside diameter?
Fords tended to have LARGE clutches.
I personally need one that is 225mm (8 7/8") with a Ford 1 1/8 (might bw 1 1/16) 10-spline. Apparently this DID exist for one year of 4 cylinder Mustang in the 1980s.
My friend Alex needed the same clutch, he just called up Clutchnet and gave them a credit card number, a short time and $250ish later he got a puck clutch with a Mazda diameter and Ford spline.
Ar some point it starts to look like adapting a 7.5" multidisk is a sane idea. But the majority of those you find on eBay are for Chevy.
Find a local industrial "clutch and brake" shop. I picked one up locally with a Ford spline in a Nissan disc size and it was a 1 day affair.
djsilver said:Find a local industrial "clutch and brake" shop. I picked one up locally with a Ford spline in a Nissan disc size and it was a 1 day affair.
^ This.
The shop that relines our shoes and clutches will make anything you need.
