The rebuild and conversion of my Radical Club Sport from D to C sports racer class continues. I've been doing a massive renovation project so it's dragged on for months, and, it turns out, finding some stuff for an older sports racer they didn't make too many of can be a challenge.
What I've got so far:
- Mostly disassembled car.
- Clean, low miles Hayabusa engine w/ everything needed to make it run.
- Appropriate mounts from Radical, which actually fit!
- Rill Tech CNC flapper/baffle oil pan/windage trays/overdrive oil pump gear.
- Rill Tech trimmed + car configured wiring harness.
- Stack 8100 dash. Oil + fuel pressure, oil + water temp, tach on one unit. W/ harness, senders, oil warning LED, 4 stage shift light.
- Custom fuel cell from Fuel Safe.
- Custom push-pull shift cable to route under cell.
- Miscellaneous thermal management materials and plumbing.
Whats conspicuously missing is a header. The system that was on the car in it's GSXR1000 incarnation was sort of a POS, so I'd like something proper, and while I'm not a bad weldor, I'd prefer to sub the job out to someone who does this every day.
Here's a whole slew of pics of my situation, some solutions, and a fixture I made...
So - I've found 3 places - Rill Tech, who will sell me a stainless and Inconel header for $1800 (I'm not kidding) Hy Tech who do this stuff - see pic of Citation sports racer header in album - and Downs in Sonoma Ca who I've yet to contact.
Seeing as the car is in MD near DC, I've made a fixture which has a mock-up of a 'Busa head - or at least the exhaust ports - and the area of the frame through which the secondaries have to exit.
I fear that I'll end up using 3 days in the shop and a bunch of universal bends from Speedway Motors and cobbling up something by myself, but does anyone know anyone I haven't thus been able to google up who's good for this stuff?
oldtin
SuperDork
6/1/12 10:27 p.m.
IIRC Keith has a neat tool for mocking up headers so then it's more a matter of who can bend up some steel/stainless and stick it together.
Wheels77 (Andy) is a header legend almost as much as a Challenge legend
oldtin
SuperDork
6/2/12 8:29 a.m.
Seeing as I have something that conveys spent fuel/air mix out the back, a fixture and a set of Hayabusa exhaust stubs, I'll go all Per Schroeder on the problem and do as he did on the LeGrand.
I'll probably get a "real" system later, but for now, if I can find a chunk of a day next week I'll do this:
![](http://grassrootsmotorsports.com/media/img/projectcars/legrandnewheader.jpg?js&js&keepThis=true&TB_iframe=false&height=600&width=700)
In reply to motomoron:
Very interesting, I look forward to builds like these, keep us posted w/ pics
I fit up a 4 into 1 equal length FZR header for a DSR on my kitchen table over one winter. 90/45/22.5 bends from a U- bend header kit held together w/ hose clamps, witness lines till a section could be tacked w/ tig. Final fit and weld w/ exhaust spigot and collector jigs and fixtures.
Lotta work and these were my pre-internet days... always looking for new ideas.
In reply to fasted58:
You had a DSR on your kitchen table ? :-p
Well, the old ones (LeGrand era) were about small enough ![](/media/img/icons/smilies/laugh-18.png)
Keith
MegaDork
6/3/12 11:29 p.m.
Ice Engine Works stuff (aka "Header Lego") is awesome. But you can get a bit carried away.
![](http://targamiata.com/images_lrg/IMG_8503.jpg)
Don't mind the welds, I was learning how to TIG on that project. Held together just fine! Header lego isn't super-cheap, but it's significantly less expensive than it was when FM bought their set and it's about the price of an off-the-shelf Racing Beat header for a Miata. If that lets you build one custom header as opposed to buying one, you'll pay for it on the first try.
A cheaper option is to use the following progression. This is what I did on my Locost.
- flexible hose (like pool hose) of an appropriate diameter and cut to length
- welding rod following the route chosen by the hose, bent to only 4" or 6" radius to match the available mandrel bends
- construction out of mandrel bends
![](http://cheapsportscar.net/images/ePIC00019.jpg)
Thanks Keith + everyone.
I have Keith's Locost book and may have said out loud "that's a great idea" on using plastic accordion hose to mock up the header.
The header-lego is just too expensive for the number of uses - that should be a "GRM community toolbox" rental tool.
For now I'm going to use my fixture, the stock Hayabusa exhaust stubs + flanges, the system that was on the car, and a few universal exhaust bends I got from Speedway Motors. I can make something functional and possibly even workmanlike.
At a future date I'll send the fixture to HyTech and have him build a 4-1 system out of mild steel for which I'll build a proper rear pipe and have the whole mess Jet-Hot coated. Maybe even a Burns muffler...
peter
Reader
6/4/12 12:06 p.m.
I wonder if this isn't the sort of tool you can use once, then eBay for 75% of cost? Heck, you might get lucky and do even better, but going in knowing you'll lose some money could get you a buy-it-now buyer...
Keith
MegaDork
6/4/12 12:25 p.m.
If a $400 tool (the one I've used) means you can build your own header instead of buying a $900 one, it's not too expensive.
