acfreak
acfreak
3/15/20 1:42 a.m.
Will i need to take this to the machine shop to get it repaired or is the damage minimal enough where the headgasket will be able to seal it?
JmfnB
JmfnB MegaDork
3/15/20 4:28 a.m.
I will say machine shop with a light bit of bowl work.
Patrick
Patrick MegaDork
3/15/20 6:03 a.m.
Yeah that's not great, i'd have it fixed or it may be cheaper to grab another head
Streetwiseguy
Streetwiseguy MegaDork
3/15/20 7:31 a.m.
Machine shop.
Knurled.
Knurled. MegaDork
3/15/20 7:56 a.m.
+4.  If a gasket seals that it would be a miracle.  That is the absolute worst place to have a surface imperfection, let alone a gouge.
Probably should have the decks skimmed anyway because MLS.
wheelsmithy
wheelsmithy UltraDork
3/15/20 8:49 a.m.
I'm not suggesting it as the best idea, but if money is tight, and/or you are adventurous, glue some 60 grit to a glass tabletop, and resurface it at home. I worked in a junkyard, and we used a huge belt sander for this very thing. I put together a lot of junk that ran perfectly. Added bonus: free compression bump.
bentwrench
bentwrench SuperDork
3/15/20 11:06 a.m.
That gasket surface needed refinishing before the gouge, now there is no question.
Purple Frog
Purple Frog Reader
3/15/20 11:19 a.m.
If you were in a third world country, and poor, you could easily surface it on a glass tabletop.  If not so poor, you could even TIG in some material to file back down to smooth.
That said, you had the head off for some unspecified reason.  Go ahead and do it right.  A machine shop rebuilt head will be better (less risky) than a junk yard head.
dean1484
dean1484 MegaDork
3/15/20 11:42 a.m.
So how did that happen?
Purple Frog
Purple Frog Reader
3/15/20 11:51 a.m.
Usually its a 15" Craftsman screwdriver than someone used to pry the head off...  frown wink
TurnerX19
TurnerX19 Dork
3/15/20 12:07 p.m.
Looks to me like the head got dragged on one of the studs during removal.
Purple Frog
Purple Frog Reader
3/15/20 12:10 p.m.
Better theory
acfreak
acfreak New Reader
3/15/20 11:22 p.m.
In reply to Purple Frog :
sadly, that's correct. :( lesson learned. first head i've ever pulled.
Knurled.
Knurled. MegaDork
3/16/20 8:03 a.m.
In reply to acfreak :
Almost everyone's done it at some point.
m0PZoYmANdoEdts3XEeYPzqLMpxALeQIMd7MRv4auXeAy6Omn5OByrZ6TUJw1Wka
