shuttlepilot
shuttlepilot New Reader
1/11/09 12:18 a.m.
I have a defroster grid on a 94 VW golf that doesn't seem to work. I am getting 12V to the electrical attachment points and drawing 2 amps when switched on. Still it doesn't defrost or not heating things enough to defrost.
Is there some amperage it should be at or a way I can check the condition of the lines? Does age come into play with these systems?
Woody
Woody Dork
1/11/09 6:16 a.m.
You most like have a break along the grid. This could be as simple as a scratch that interrupts the electrical continuity. The grid is usually made up of electrically conductive paint, often gold based.
A few years back, I broke one of the metal electrical connectors for the defroster off the back window of a Miata hard top. I needed electrically conductive adhesive to repair it. As I recall, it came from Permatex.
44Dwarf
44Dwarf Reader
1/11/09 7:26 a.m.
if its drawing 2 amps something should be hot...
They have a paint at the parts stores for fixing the brocken area looks like nail polish but as stated above it conductive.
randyvr6
randyvr6 New Reader
1/11/09 2:25 p.m.
It should draw a lot more than 2 amps. I believe it is around 20.
You should be able to see broken lines, but you could do a continuity test across each line. A broken line only keeps that line from heating up.
There should also be a relay somewhere; you may want to remove it and try jumping the socket with a fused jumper wire and check the amperage again. Age should not be a factor on the grid performance. Have you tried removing the connectors to the grid to make sure there is no corrosion?
Tommy Suddard
Tommy Suddard
1/11/09 2:49 p.m.
BMW sells a repair kit with the paint and stuff in it.
car39
car39 Reader
1/11/09 3:32 p.m.
If you don't see a break, go down the grid wih a test light. It will go off when you hit thebreak
ArtOfRuin
ArtOfRuin Reader
1/11/09 4:55 p.m.
Permatex makes a defroster repair kit. About $13 at your local PepAdvanceZone.
DN2yMqnb0PsG0LzSnnDzgIUi4i7gh0ulio324k4vJZf43suqM5MbjbUQzKKUbszz
