These are central questions. I probably could've ballparked something to set constraints before asking for prognostications on what will continue to be available in the tire department. I've got some thoughts for all those questions (but am more than happy to learn if I've got bad assumptions, etc).
AngryCorvair wrote:
i'd recommend some performance-focused selection criteria, such as:
required rolling radius to achieve desired overall gearing (vehicle speed @ RPM in each gear);
I guess the big concern here will probably be getting 2nd as well-placed as possible to cover most autox conditions. Autox is the only time the stopwatch will count... There are a decent range of rearend ratios, but I will take your advice and do the math on a few tires sizes with the commonly available ratios... Anybody compiled statistics on autocross speed ranges?
required wheel size to package desired brakes;
Semi-secondary. Brakes that fit inside 15s should be overkill for autox, and at least sufficient for track days (it would be annoying to have to ease up due to faded brakes, but I won't be roadracing, and a 2300lb car with 250hp shouldn't tax breaks that size, I hope).
required size to carry the expected loads;
I'm a little torn here. It does seem like all the tire in the world is in use in the SM cars, and I'm going to wind up in XP or a modified class... Actually, I think we've just hit my facepalm moment (and it's a doozy): I need to figure out whether I'm worried about R-comps or slicks...
and then the aesthetic considerations such as will it look dorktacular with a 45-series tire on a 15" rim?
but that's just me...
I know it sounded dumb to chuck that aesthetic consideration out there so early in the process. And it's not etched in stone; however, I think the physical limitations of the car are such that by the time we get to a 16" wheel, the car's going to be forced to sit too high. Even the big widths in 15" are getting pretty tall for this car, though availability and brake fitment get harder below that, too
It's a little bit of a funny situation, because I've decided what I really want to build, and now that I've roughed that in, I'm willing to scale the SCCA class chart 'til I find what allows that architecture, then pin down the details to not exit that class on a minor decision. Even though competition is in this car's future, that role is still "for fun". In reality, I don't think there's a good niche in SCCA autocross for a significantly re-engineered street car if you're worried about beyond the local/regional level. As soon as you start moving hard points, having windows and a passenger seat become liabilities. I plan to move my "serious" competitive jones to spec miata once I have this car "done"(ish).
In any case, it was certainly an oversight on my part to ask this question before pinning whether I'm using R-comp street tires or slicks for autox.
