singleslammer
singleslammer Reader
4/3/12 7:40 p.m.
Some of you might have seen my other thread about my 66 Galaxie Vert, now I am considering what to do next. The 352 is getting pretty tired and needs an overhaul at the least. The c6 trans is in the same shape. I have considered doing this but it seems like a waste for a car that has very little market value, in the grand scheme of things, and then still have a 13 MPG motor package. Originallity is of no concern. I would love to get this beast into the 20s and the only way I can see to do that is with a swap and diesel seems the logical choice. Budget is tight so bring on the grm ideas!
DoctorBlade
DoctorBlade Dork
4/3/12 7:43 p.m.
Duramax/Allison, Cummins I-6 or the Cummins 4bbt. I think that's basically what it boils down to.
danvan
danvan New Reader
4/3/12 7:45 p.m.
thats a very heavy motor/trans combo for a car
Ranger50
Ranger50 SuperDork
4/3/12 7:45 p.m.
302/aod. Even in that big of a land yacht, it will get 20. Overdrive and mid 3.xx gears are the keys.
ShadowSix
ShadowSix Reader
4/3/12 7:50 p.m.
Ranger50 wrote: 302/aod. Even in that big of a land yacht, it will get 20. Overdrive and mid 3.xx gears are the keys.
I'd say ranger is on to something here: '90 Crown Vic gets 22 MPG
Osterkraut
Osterkraut UltraDork
4/3/12 7:52 p.m.
Isuzu 4 cylinder... they can be adapted to GM transmissions...
EvanB
EvanB UltraDork
4/3/12 7:55 p.m.
http://detroit.craigslist.org/wyn/cto/2935318487.html
Something like that should work, gain some money back by scrapping the rest.
ShadowSix
ShadowSix Reader
4/3/12 7:59 p.m.
EvanB wrote: http://detroit.craigslist.org/wyn/cto/2935318487.html Something like that should work, gain some money back by scrapping the rest.
Is the motor in something like that north-south, or east-west?
EvanB
EvanB UltraDork
4/3/12 8:04 p.m.
north-south
ShadowSix
ShadowSix Reader
4/3/12 8:09 p.m.
Hmm, this could displace the M-B OM617 as my dream '89 4Runner motor...
DoctorBlade
DoctorBlade Dork
4/3/12 8:09 p.m.
danvan wrote: thats a very heavy motor/trans combo for a car
Good point, it certainly won't do for a sporting car. If you're more into eating up highway miles and whatnot, it'd be great. Still, when you consider you're able to get up to 500HP/1100 ft-lbs of torque with minor work, it'll pay you back. :)
EvanB
EvanB UltraDork
4/3/12 8:22 p.m.
http://www.isuzudieselswapper.com/
danvan
danvan New Reader
4/3/12 8:22 p.m.
you still have to find a way to hold the front end up i am sure some one on here has the weights at there finger tips, i am willing to bet the duramax allision combo comes in over 1000 lbs or 500 kg where i come fromIn reply to DoctorBlade:
Ian F
Ian F UberDork
4/3/12 10:21 p.m.
+1. If the budget is tight, this is the best option. You can buy a lot of gas for the cost difference of a diesel conversion.
jimbbski
jimbbski Reader
4/3/12 10:37 p.m.
I say FI 5.0 and an AOD trans.
My dad had a 66 Ford Custom which was just the base version of the Galaxie. It had a 289 with a 3 speed auto and would get 20 mpg on the highway. It was light at 3600 lbs but with a more modern version of the 289 I see no reason why you couldn't get low 20's. And a much easier swap then a diesel one.
Knurled
Knurled Dork
4/3/12 10:54 p.m.
Bolt in a 428/C6, and stuff some taller gears in that 9".
It's an orange to your apple, but I had a 429/C6 car that would do 24mpg on the open road. Mildly lumpy cam, an Autolite 4300 that actually worked (I think I had the only one. I had good luck with a Digifant VW, too...), 2.77 gears, and brisk yet smooth driving. I don't know if the cam helped or hurt, but it was pleased as punch cruising down the road at 2000-2400rpm. (30mph/1000rpm)
curtis73
curtis73 SuperDork
4/4/12 2:10 a.m.
The 6.0L powerstroke is a pretty easy swap as far as oil pan fitment, bellhousing pattern, etc. The 6.0L is hated for a few reasons, but all of them are easily cured by the aftermarket. EGR cooler and oil cooler are the big ones to take care of first. Otherwise its a fine diesel.
I saw a 6.0L in a 65 Galaxie that looked like it was easy, but I don't know the details.
Skip the 6BT and 4BT cummins... they are insanely tall. Unless you want 10" of cylinder head poking through the hood, just keep walking. 7.3L is a great powerstroke, but its also a very tall engine.
Twin_Cam
Twin_Cam UltraDork
4/4/12 3:49 a.m.
curtis73 wrote: Skip the 6BT and 4BT cummins... they are insanely tall. Unless you want 10" of cylinder head poking through the hood
You say all of that like it would be a not totally badass thing.
warpedredneck
warpedredneck New Reader
4/4/12 4:49 a.m.
7.3 idi, with c6, shouldnt be much heavier than the 352, you can also turbo it for giggles
stumpmj
stumpmj Dork
4/4/12 8:09 a.m.
If you're on a budget, forget the diesel. They're all expensive or broken. 302 or an LSx like the 5.3L can get you there.hooked to the appropriate transmission if you keep the fuel injection.
singleslammer
4/4/12 4:55 p.m.
Alright, you guys have made some valid points on gasser fuellie motors. I was thinking a 5.3l and 2wd 4L60/80E all from one wrecked truck would be ok. I also have access to a number of old busted panters (86-88 Grand Marques). I was just thinking how freaking cool it would be to run veggie oil through the Galaxie. A GM LM7 would be alright too I guess... They are insanely easy to make a fair amount of power out of. I wouldn't even need to change my tall ass rear ratio.
Vigo SuperDork
4/4/12 7:41 p.m.
im with warpedredneck on this one..
Just get a non-turbo 80s f-series diesel and use that. Should be simple and definitely will be cheap. May still need to gear taller, though.
81cpcamaro
81cpcamaro Reader
4/5/12 8:04 a.m.
warpedredneck wrote: 7.3 idi, with c6, shouldnt be much heavier than the 352, you can also turbo it for giggles
Good choice, they were in Ford trucks 1988-94 (even one version was turboed in 94). Weight is listed at 920 lbs so it is heavier than the 352, but within reason. They are about the same size as a Big-Block Chevy or Ford 460. Taller gears probably are needed or a good overdrive E4OD/4R100 AT or 5-speed if gear rowing is what you want. If I remember right my 7.3L IDI would turn 3300 rpms max, best gas mileage was at 1800-2000 rpms.
Edit: Even in the 6500+ lb F350 it was in, I was getting 18 mpg combined driving. Never took a long trip but it probably could have topped 20 mpg. Should do better in a lighter vehicle.
iceracer
iceracer SuperDork
4/5/12 8:25 a.m.
How much beter mileage would you need to get to offset the 30+- cent premium for fuel ?
curtis73
curtis73 SuperDork
4/5/12 8:30 a.m.
In reply to iceracer:
Not much. I recently figured this out. At the time I was paying $3 for gasoline in my F150 gasser getting 13 mpg. At $3.40 for diesel (a 13% increase) I would have had to get 14.7 mpg to offset the fuel cost. I'm actually getting 18-20 in my diesel van so it was a definite win.
When you also calculate in the fact that my F150 was a 3.08 rear and made 345 lb-ft of torque, and my diesel is a 3.73 rear end with 550 lb-ft of torque, its kinda a no-brainer
lffkt9ImE9196l8IrzkisWDNCj6wt8TLaxmiLjHT7V3PQQxJq9ll4yYFU6pFXMmb
