Jaynen
Jaynen SuperDork
1/18/18 5:12 p.m.
Ok I was trying to put the pads in to the "bracket" and then mount it into the caliper I will try mounting the bracket first, then pads into it, then sliders
Jaynen
Jaynen SuperDork
1/18/18 6:03 p.m.
That was surprisingly easy doing it that way, I found a vice I could use to push the piston back it made my nice clean "apple juice" of new fluid from when I did the rears all murkey so I drained it and replaced it again before I do the front stainless lines.
Any suggestions on how long to gravity bleed them for if I am just letting it pee on the caliper?
AngryCorvair
AngryCorvair UltimaDork
1/18/18 6:22 p.m.
Go to HomeDeLoweNards and get some clear plastic (vinyl?  Tygon?  Whatever) tubing that barely fits onto the bleed screw.  Loop it up over the suspension, then down into a clear bottle.  When the fluid coming out is clean, that corner is done.  Might take 15 minutes per corner, and you'll have to top off the MC A bunch of times.
Jaynen
Jaynen SuperDork
1/18/18 6:45 p.m.
hmm not near that much seemed to come out when I did the rears it was definitely coming out but I never had to top it off really the fluid was bright yellow applejuice like what I put in however. We also have snowy icy roads right now so I have to make due with what I have in the garage if I want to finish this
BzihtHbqOVdBBoNOjAkJeChmGK22XG9N0TkexvTbi4RLtuMcjEUTQNDbFAXVISCm
