wbjones
wbjones UltimaDork
10/31/14 7:26 a.m.
to which I should know the answer, but obviously don't
I know that to adjust the brakes on a car with drum brakes, you adj. while backing up … is it the same with rear disks ? … just put new pads on the back of the CRX and immediately put it on the tow dolly for the trip to Road Atlanta tomorrow …
it would probably be a good idea to have actual working rear brakes when I take it out on track
gearheadmb
gearheadmb New Reader
10/31/14 7:27 a.m.
Just pump them up.
Matt B
Matt B SuperDork
10/31/14 8:39 a.m.
Yeah, no need to back up. Just a few pumps should be good.
HappyAndy
HappyAndy UltraDork
10/31/14 9:04 a.m.
Some rear calipers have an adjustment screw for the integrated p-brake, is that what you are talking about?
wbjones
wbjones UltimaDork
10/31/14 11:49 a.m.
no … I knew these self adjusted, was just making sure how they did …
I had assumed just by using … thanks folks for confirming
wlkelley3
wlkelley3 SuperDork
10/31/14 11:49 a.m.
Like Miata's do.
wbjones
wbjones UltimaDork
10/31/14 11:51 a.m.
wlkelley3 wrote: Like Miata's do.
while that's good to know, I've never owned a Miata, nor do I ever expect to
pitbull113
pitbull113 Reader
10/31/14 2:11 p.m.
Please leave now before this gets ugly.
wbjones
wbjones UltimaDork
10/31/14 7:09 p.m.
my first car was a convertible (a '65 Sunbeam Alpine) … I quickly found out that I don't like convertibles ….
pitbull113
pitbull113 Reader
10/31/14 8:42 p.m.
wbjones wrote: my first car was a convertible (a '65 Sunbeam Alpine) … I quickly found out that I don't like convertibles ….
Yes but the answer to every question is Miata!
novaderrik
novaderrik PowerDork
11/1/14 12:46 a.m.
gearheadmb wrote: Just pump them up.
scottdownsouth
scottdownsouth Reader
11/1/14 4:44 a.m.
No. You work the e brake while backing up. Then you do a high speed e brake test, if you do a 360 your good !
wbjones
wbjones UltimaDork
11/1/14 6:39 a.m.
mad_machine
mad_machine MegaDork
11/1/14 7:43 a.m.
hopefully you did not like the open feeling.. as the way a sunbeam feels is vastly different from how a Miata feels
wbjones
wbjones UltimaDork
11/1/14 8:12 a.m.
no … it's the glare … can't deal with it … I've only opened the sun roof on my Integra … maybe 5 or 6 times in the 14 yrs I've owned it …. and have yet to open the sun roof on my new Sonic
turboswede
turboswede UltimaDork
11/1/14 10:12 a.m.
wbjones wrote: no … it's the glare … can't deal with it … I've only opened the sun roof on my Integra … maybe 5 or 6 times in the 14 yrs I've owned it …. and have yet to open the sun roof on my new Sonic
wbjones
wbjones UltimaDork
11/2/14 7:08 p.m.
use um all the time … still doesn't stop the glare that comes in around the sunglasses … much more controllable with a roof as opposed to an open top …
Kenny_McCormic
Kenny_McCormic PowerDork
11/2/14 7:47 p.m.
Some work from normal use, others adjust by using the parking brake. Either way they don't self adjust very well if you don't pack the adjusters with grease and get them manually adjusted reasonably close on installation, and assemble them correctly.
aircooled
aircooled UltimaDork
11/2/14 10:36 p.m.
Just buy the damn Miata man!!!
Interestingly enough, a lot of people that drive convertibles rarely drive them with the top down anyway. Besides, the BEST time to drive a convertible is on a hot NIGHT.
SnowMongoose
SnowMongoose Dork
11/2/14 10:46 p.m.
wbjones wrote: I quickly found out that I don't like convertibles ….
Amen!
(and I say that as someone who currently owns one and a half examples of 'the answer')
wbjones
wbjones UltimaDork
11/3/14 5:27 a.m.
Kenny_McCormic wrote: Some work from normal use, others adjust by using the parking brake. Either way they don't self adjust very well if you don't pack the adjusters with grease and get them manually adjusted reasonably close on installation, and assemble them correctly.
wbjones
wbjones UltimaDork
11/3/14 5:28 a.m.
aircooled wrote: Just buy the damn Miata man!!! Interestingly enough, a lot of people that drive convertibles rarely drive them with the top down anyway. Besides, the BEST time to drive a convertible is on a hot NIGHT.
nope … not going to happen … the only way I'd ever have a Miata would be as a race car … but since I'm happier driving FWD … if I ever got a "real" racecar I'm betting it would be a Honda
Kenny_McCormic
11/3/14 6:08 a.m.
Grease the hell out of the moving parts on the adjuster, the threads and the cup deal on the other end, otherwise they seize up pretty fast and stop working. There's not much force exerted on the adjuster by the adjusting arm.
3TgBbS0IzCAOKVzK9JAno3aEOwjUn7lhrFY2jEw1zjAJ0wDLCCUaD6vZ3E9l4xxB
