For the first time in many years, I'm a whits end with a car project, and am pondering actually taking a vehicle to a shop.
A bit of back-story. '96 E36 lost the clutch after start finish at Daytona in October (dual mass flywheel had lots of slop, and the disc had started to separate) . Since I have an S52 sitting in the shop, figured it would be a good time to just go ahead and engine swap the high mileage but super reliable M52 out. I've done a couple of E36 swaps in the past, never had any problems. Dropped the engine / tranny, put new detents in the tranny, VANOS kit, etc. The typical while it's out stuff. Went back in without too much trouble, started right up with the M52 DME, while I figure out what I want to do for tuning.
Okay, so have running engine try to slip it into gear......nada, nothing.......so I pull the tranny and see if I can find anything wrong. Nothing stands out....so replace master and slave.....reinstall.....nada.
So far: New OEM slave, master and SS flex hose, new clutch fork, SS pivot pin, new TOB, I've pressure bled, gravity bled, stroked the slave off the tranny. The ZF does feel more notchy with the engine not running, but I'm assuming thats the fresh detent kit. I can slip it into gear with the engine running on the 2 post, but I can't force it to slip with the engine running so I don't think it's close to releasing. You can see me trying to get it to slip in the video link below and the engine stalling.
Clutch kit is a lightly used JBR kit off another running track car. I've been in touch with JBR (quite helpful) and they are adamant that the parts I have should work together correctly. They are also adamant that the disc goes in backwards from typical E36 install, with the spring hub extension facing the flywheel.
I put a small inspection hole in the bellhousing so I could get a boroscope in there
It's clearly moving the TOB, but I'm guessing I'm getting 6-7mm of movement. JBR thinks I need about 11 mm for the pressure plate to release correctly.
There are some good wrenches on this board, so hopefully someone will see something I don't. I'm going to give it one more shot at bleeding it, and then I'm having it towed to a shop.
Thanks!
Glenn
