Duke Dork
6/23/09 2:31 p.m.
I know I won't get much without plates, but I want to get some negative camber up front in my E46 while staying in stock class.
I've heard there are removable alignment pins on the front struts that will allow a little more adjustment, but I don't know where they are or how to remove them.
Are they the little studs that stick up through the top of the strut tower just inboard of the 3 flanged bolts? If so, how do I get them out?
TIA.
Soma007
Soma007 New Reader
6/23/09 2:44 p.m.
Yep, thats it. One pin per side. I hear you can force them out with a hammer but I've never tried it.
Otherwise you'd need to remove the strut to get better access.
Soma007
Soma007 New Reader
6/23/09 3:02 p.m.
http://www.unofficialbmw.com/images/e46.pdf
Page 21
Sounds like you can just force the pin out by hammering it downwards.
Duke Dork
6/23/09 3:40 p.m.
Excellent! Thank you. I've heard of people cutting the pins off with a cold chisel, but it seems to me they are designed to punch out.
Thanks for that prompt linkage.
2001bmw330ci
2001bmw330ci
6/17/10 2:25 p.m.
In reply to Duke:no no no no the pin has threads twist it out with pliers
7UN2zIQBAXnCYtUt3iHioRQUEImuwecwBuqAxrVCV99fFk8UoaPRpyYOQRCP7hDD
