steronz
steronz Reader
2/9/16 9:37 a.m.
Do my research for me, GRM :)
I found a lead on a cheap Focus shell. I like the Focus, I used to own one, but I don't remember much about making them fast. SVT swap, 2.3L Duratec, 2.5L (4 banger or 6-cyl)... what's the best dollar/hp ratio for a truly bolt-in solution? (No thanks on the RWD V8 conversion).
calteg
calteg Dork
2/9/16 10:04 a.m.
2.3L duratec. Off the top of my head, it gives up 10hp to the SVT mill, but makes more torque, takes regular gas, and is likely much cheaper to source.
RossD
RossD UltimaDork
2/9/16 10:19 a.m.
Well the earliest ones either came with the 2.0 SPI, 2.0 Zetec SVT or normal 2.0 Zetec . They have the same bellhousing pattern, which is the classic Ford 4 cylinder but with the starter moved up in place of one of the bolts so that the starter doesn't occupy the same location as the axle shaft.
The Duratec has a different pattern but I believe all of the ford 4 cylinders use this bolt pattern since. This includes the MZR from Mazdas and the RWD Duratec from the Ranger. Again, I believe the 4 banger Ecoboost share this pattern too.
RossD
RossD UltimaDork
2/9/16 10:28 a.m.
If you wanted to be truly different, you could cut the one bellhousing bolt 'ear' off of the block of a 2.3 Turbo Lima (to make room for the starter) and have the only fwd, transverse, turbo, 2.3 Lima in existence.
I'm sure there is a bit more to it...
WOW Really Paul?
WOW Really Paul? MegaDork
2/9/16 12:38 p.m.
3.0L duratec bottom end under csvt top end parts, coupled to the csvt's mtx-75. Wiring would suck, but it's been done before.
RossD
RossD UltimaDork
2/9/16 1:18 p.m.
In reply to WOW Really Paul?:
Why stop there? Use the 3.4 SHO V8 instead!
bearmtnmartin
bearmtnmartin Dork
2/9/16 1:24 p.m.
I have a friend putting a Focus engine in a mustang ministock. He said it aligns perfectly with a T5 bellhousing although only two bolt holes lined up. So I guess I am saying transverse V8!
steronz
steronz Reader
2/9/16 1:31 p.m.
RossD wrote: The Duratec has a different pattern but I believe all of the ford 4 cylinders use this bolt pattern since. This includes the MZR from Mazdas and the RWD Duratec from the Ranger. Again, I believe the 4 banger Ecoboost share this pattern too.
So what you're saying is, 2013 Escape engine + MTX-75 (duratec bellhousing) = possible bolt-in 243hp focus? I mean, aside from all the hard stuff.
RossD
RossD UltimaDork
2/9/16 1:38 p.m.
If you're referring to a 2.0 Ecoboost, yes that's my understanding. Don't spend money and find out different and yell at me though, do more research. I haven't played with the Duratec or Ecoboost engines. I've had my hands on a Lima and still have a Zetec, however.
RossD
RossD UltimaDork
2/9/16 1:40 p.m.
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=25303
Read the first 4 bullet points.
captdownshift
captdownshift UltraDork
2/9/16 1:41 p.m.
Volvo T5
RossD
RossD UltimaDork
2/9/16 2:58 p.m.
Did some more digging, and it appears that the 1.0 Ecoboost is a newer design. I'm not sure if that bellhousing matches anything else. The 1.6 Ecoboost is based on the Sigma family of engines and have their own bellhousing pattern. The 2.0 and 2.3 Ecoboost seems to match the Duratec/MZR 4 cylinders bellhousing.
http://fordperformanceracingparts.com/download/tipspdf/enginehistory.pdf
XZYwXq64F9TOmiDAigB1XxCQCieA9RE2hkKPTDD9NXp6YhmoD7jeTw8beaXWVzl6
