mrdontplay
mrdontplay Reader
4/22/09 4:18 p.m.
I have an 84 chevette project car. I'm pretty sure the ECU is fried or shorting out. Its runs crappy sometimes, great others and the code reader can't read it. I'm thinking about just getting an older style carb like the one on my 79 and eliminating the computer. What problems might I run into? this is just so I can drive the car some until I can get a V6.
Bobzilla
Bobzilla Reader
4/22/09 4:19 p.m.
Grab the Distributor too. Not sure how much control the primitive computer has...
mrdontplay
mrdontplay Reader
4/22/09 5:38 p.m.
I'm pretty sure it's still vacuum advance, does that make a difference?
Jensenman
Jensenman SuperDork
4/22/09 6:47 p.m.
If that's a C3 computer carb setup you shouldn't have any problems as long as it is a vacuum dizzy and I believe electronic timing didn't show up until GM went with fuel infection (the old TBI systems).
kcbhiw
kcbhiw Reader
4/22/09 10:53 p.m.
Shall I dare say skip the carb and go MegaSquirt?
Nashco
Nashco SuperDork
4/23/09 12:17 a.m.
kcbhiw wrote: Shall I dare say skip the carb and go MegaSquirt?
+1
Trans_Maro
Trans_Maro Reader
4/23/09 1:26 a.m.
Jensenman wrote: If that's a C3 computer carb setup you shouldn't have any problems as long as it is a vacuum dizzy and I believe electronic timing didn't show up until GM went with fuel infection (the old TBI systems).
I don't know about the Chevettes but the '81 TTA with a CCC ECU also had full electronic timing control.
The giveaway will be if your distributor has a vacuum can as Jensenman said.
Shawn
GVX19
GVX19 New Reader
4/23/09 7:50 a.m.
+1
+1
oldopelguy
oldopelguy HalfDork
4/23/09 10:02 a.m.
Not sure megasquirt actually works with a computer controlled carb guys....
Just swap on a Weber carb like every one else and you'll be fine.
skruffy
skruffy Dork
4/23/09 10:07 a.m.
You'd have to switch to a TBI setup or something to megasquirt. I'd imagine a carb that'll work could be had from a junkyard for $20 or so. A megasquirt will be much more than that.
ClemSparks
ClemSparks SuperDork
4/23/09 10:34 a.m.
I'll also say that my experience (with an '83 Z28) leads me to believe you'll want to swap the distributor as well. However, that's based on a Z28...I'm not sure about the Chevette.
96DXCivic
96DXCivic Reader
4/23/09 10:48 a.m.
oldopelguy wrote: Not sure megasquirt actually works with a computer controlled carb guys.... Just swap on a Weber carb like every one else and you'll be fine.
+1
Nashco
Nashco SuperDork
4/23/09 11:26 a.m.
Perhaps not, but Megasquirt does work with a TBI unit, which adapts just as easily as a Weber carb. Sure, it'd cost more for the MS, but the rest of it (TBI, fuel pump, etc.) is super cheap. TBI unit from a GM 4 cylinder, external fuel pump from a Ford van/truck, and a handful of sensors from the GM 4 cylinder you pull the TBI off...less than $100 at the junkyard. As a bonus, when he upgrades to another engine the MS, sensors, and fuel pump will work on that application too, while his Weber would be undersized and useless to him. A little more effort now will save effort in the long run.
I just swapped MS in place of a Weber 2 barrel on my Volvo 122. Totally worth it.
Bryce
maroon92
maroon92 SuperDork
4/23/09 12:01 p.m.
megasquirt is exprensive!
Nashco
Nashco SuperDork
4/23/09 12:21 p.m.
maroon92 wrote: megasquirt is exprensive!
It's all relative, I suppose. Even brand new ones are only $140 from diyautotune.com and of course if you're good at finding deals there are used ones out there much cheaper than that. I thought that was pretty cheap.
Bryce
mrdontplay
mrdontplay Reader
4/23/09 3:21 p.m.
This is just to get it running good enough that I can drive it until I get the V6. Once the V6 goes in the 1.6 is going on an engine stand, getting a turbo,FI, getting build, and waiting for another vette to come along. That will require megasquirt.
QDaPkrZTHyhx2ebTMcCewDb96KRPBj28CJURiku6n1CHE6YNMm0cWchsUt6kZV8j
