carguy123
carguy123 UltimaDork
12/15/19 3:43 p.m.
In the back of my mind I seem to remember that the engine ecu needs to be mounted to metal/ground, but the mounting place for my GM ecu is on fiberglass.   Am I daft?
I can move it over to metal as everything will reach, I'll just have to move the fuel line filter.
codrus
codrus UberDork
12/15/19 4:01 p.m.
It would only need to be mounted on metal if it requires that the case be grounded, and I doubt that's actually going to matter on a modern car.  There will be multiple ground wires in the harness.
If by some chance it does matter, you could just run an additional ground wire from a screw on the case to the chassis somewhere.
frenchyd
frenchyd PowerDork
12/15/19 4:12 p.m.
In reply to carguy123 :
I should think that vibration is a concern. Electronics suffers greatly during heavy vibration.  Remarkably there are spots even in the same panel where vibration is worst.
Move at your own risk.
Shadeux
Shadeux Reader
12/15/19 4:16 p.m.
Mount it on a pillow if you want, just run a ground to it as codrus wrote.
carguy123
12/16/19 12:25 a.m.
To be safe I'll run a ground.  I spent literally hours getting the fuel filter/pressure regulator mounted so I don't want to move it unless I have to.  One of the nuts was in a particularly difficult area to reach and I kept dropping it.
It fell in some of the most creative places.
AGSuyXi82hlpAdrASzQXjnzgJGOb81xDmC1TheHYRp8SG9lF48lNjCSwx753ovOq
