sobe_death
sobe_death Reader
11/18/11 10:53 a.m.
I know this may be the wrong forum to ask about decorative things, but I figure someone here DOES probably know their hardware.
I'm specifically looking for a cheaper source of these concave washers that have been popping up for the imports that basically replace every M6 fastener under your hood. Problem is, I don't know the proper name of them to search for them.
example: ebay bling
Thanks, Parker
belteshazzar
belteshazzar SuperDork
11/18/11 11:17 a.m.
i feel like i would strip those
porksboy
porksboy SuperDork
11/18/11 11:43 a.m.
Try threads for the south. I wouldn't use counter sink heads. I would use button heads with appropriate washers.
Taiden
Taiden Dork
11/18/11 11:57 a.m.
I've been throwing around the thought in my head of how countersunk fasteners handle loads differently than button head fasteners. Maybe I'll tackle this later.
Sorry that was somewhat unrelated and not very helpful.
Appleseed SuperDork
11/18/11 12:23 p.m.
Dude. I think about stuff like that all the time.
ditchdigger
ditchdigger Dork
11/18/11 12:26 p.m.
I can tell you that with a countersink and a parting tool in a lathe you could make about 60 of those an hour. Now the anodizing is another story.
Similar washers are used to spread the load on adjustable cam gears.
Decoration does have its place, even in challenge level builds. Ransom and I were discussing the difference between quality and perceived quality a while back. Little things like an attractive fastener are an inexpensive way to either draw attention or take attention away from things.
If you don't need the solid aluminum there are pressed finish washers avaliable at every fastener store in the nation
Giant Purple Snorklewacker
11/18/11 12:30 p.m.
countersunk socket-screw washer
http://www.mcmaster.com/#standard-washers/=eznif4
example part# 92908A265
ditchdigger
ditchdigger Dork
11/18/11 12:37 p.m.
Woah! a 6mm Stainless countersunk socket screw washer through mcmaster has an OD of 32mm and in stainless is $12.27 a piece.
11/18/11 12:42 p.m.
ditchdigger wrote: Woah! a 6mm Stainless countersunk socket screw washer through mcmaster has an OD of 32mm and in stainless is $12.27 a piece.
zinc plated steel 1/4" (non-socket) is $4 for a 100. They look nice enough.
sobe_death
sobe_death Reader
11/19/11 1:45 p.m.
Hmmm, well, thanks for the info! I think I've decided against it, just for the simple fact that I wouldn't be able to take my entire Civic apart with a 10mm wrench. Plus, I'll just toss all of the hardware in to get gold cad-plated when I do my headlight buckets and that should take care of the bling for my $600 car.
kTay1CRqNJv2BvmWTs7wj2bhsIArK7fgMa2YWaXpcZbMi4E5QhVILUQy5kglEYJd
