Jeff
Jeff Dork
3/7/11 7:06 a.m.
The infamous JVL built Morten Vodge Dolt is for sale.
http://www.specialstage.com/classifieds/showproduct.php/product/2210/cat/13
It needs an engine, one piston is holed according to the owner.
What would be the simplest engine to get a hold of and swap in there? I'm looking for easy to find and easy to bolt in. Honestly, this is most likely a bench exercise, I've been way to busy lately. OTOH........
Jeff
Woody
Woody SuperDork
3/7/11 7:08 a.m.
Rotary? That would take of that holed piston issue.
bravenrace
bravenrace SuperDork
3/7/11 7:31 a.m.
I learned to drive in a '74 Dodge Colt. I'd love to have another one, but I'm not sure why.
jrw1621
jrw1621 SuperDork
3/7/11 7:40 a.m.
Full Evo drivetrain
tuna55
tuna55 Dork
3/7/11 8:02 a.m.
Jeff wrote: The infamous JVL built Morten Vodge Dolt is for sale. http://www.specialstage.com/classifieds/showproduct.php/product/2210/cat/13 It needs an engine, one piston is holed according to the owner. What would be the simplest
jrw1621 wrote: Full Evo drivetrain
Woody wrote: Rotary? That would take of that holed piston issue.
Honestly, this is most likely a bench exercise, I've been way to busy lately. OTOH........ Jeff
Do you guys even read the OP? Bolt in and easy.
Honestly, I'd get another 4G54B - I've never been a fan of destroking anyway, so just throw a stock one with some better parts and it would exactly bolt in to everything, even his cool cam and new ecm.
ArthurDent
ArthurDent Reader
3/7/11 8:16 a.m.
Its in Canada I see - a Hyundai Pony 1.6L bolts right in - same motor as stock. Only 70hp or so though.
Appleseed SuperDork
3/7/11 8:20 a.m.
SRT 2.4 dood!
Jay
Jay SuperDork
3/7/11 9:02 a.m.
ArthurDent wrote: Its in Canada I see - a Hyundai Pony 1.6L bolts right in - same motor as stock. Only 70hp or so though.
I imagine it would be a bazillion times easier to find a Dodge Raider or a D50 to give up its G54b than a still-functional Pony.
SlickDizzy
SlickDizzy SuperDork
3/7/11 9:10 a.m.
Wouldn't a Starion engine or 4G63 bolt in with minor mods? I may be wrong, I'm not too familiar with the Diamond Star stuff.
bravenrace
3/7/11 9:27 a.m.
Go old school - 340!! Or go new - S2000 engine.
Moparman
Moparman HalfDork
3/7/11 9:47 a.m.
Aluminum Hemi?
ArthurDent
ArthurDent Reader
3/7/11 10:29 a.m.
There is a still a few kicking around Alberta and BC. They are quite robust mechanically but very rust prone. I wouldn't have suggested it except he asked for bolt in and its the same as the Colt motor - Mitsubishi 4G32 engine.
NGTD
NGTD HalfDork
3/7/11 11:19 a.m.
I have seen it posted on a number of other forums that windshields for these cars are unobtanium.
Ignorant
Ignorant SuperDork
3/7/11 11:38 a.m.
rebuild the current motor, its been succesful this long or a 4g32
John Brown
John Brown SuperDork
3/7/11 12:01 p.m.
I am puitting together a 2003 PT Cruiser 2.4L with 1999 Neon DOHC cams, a Wrangler/Liberty exhaust manifold, 2004 Stratus intake manifold (over cam cover like 2.3L Ford), a Wrangler/Liberty bellhousing Supra transmission. It is my intention to run everything with the factory Neon computer with the injector swap and a modified wire harness. I will use an aftermarket catalytic converter and a 2.25" exhaust to a y pipe and dual mufflers.
I am hoping to get the similar performance of the original engine (150hp) with the mileage of a swapped Neon because the weights are very similar and the final drive is similar.
petegossett
petegossett SuperDork
3/7/11 12:28 p.m.
I still have the spare 2.4(?) that came with my Colt. I was told it was a built engine, but had low compression in one cylinder. It's still in the same place I put it when I bought, and then sold, mine.
Located in 60963, make me an offer if you're interested.
FWIW, I always wanted to do a 4G63t.
1988RedT2
1988RedT2 Dork
3/7/11 12:38 p.m.
Mazda 13BT with a T04. And yes, I read the OP.
Nitroracer
Nitroracer SuperDork
3/7/11 5:56 p.m.
John Brown wrote: I am puitting together a 2003 PT Cruiser 2.4L with 1999 Neon DOHC cams, a Wrangler/Liberty exhaust manifold, 2004 Stratus intake manifold (over cam cover like 2.3L Ford), a Wrangler/Liberty bellhousing Supra transmission. It is my intention to run everything with the factory Neon computer with the injector swap and a modified wire harness. I will use an aftermarket catalytic converter and a 2.25" exhaust to a y pipe and dual mufflers. I am hoping to get the similar performance of the original engine (150hp) with the mileage of a swapped Neon because the weights are very similar and the final drive is similar.
I like the parts bin engineering with this one. A lot of different vehicles combined for one good end result.
Jay
Jay SuperDork
3/7/11 6:42 p.m.
SlickDizzy wrote: Wouldn't a Starion engine or 4G63 bolt in with minor mods? I may be wrong, I'm not too familiar with the Diamond Star stuff.
A Starion mill is essentially the same as what's in there. A 4G63 would work, but you can't use a transverse one because the bellhousing is different. You need the bottom end from one specific year of Dodge D50/Mighty Max (I think it was '88?) and then you can plunk the head from a Talon or whatever on. I think you could do some mix-and-matching of internals to get the forged crank from the DSM and whatever compression ratio you want. It all bolts together but it's not an easy, single-donor swap. Would be the same procedure as putting one into a Starion, it's been done & the info is out on the web.
John Brown
3/7/11 6:53 p.m.
BTW it puts the exhaust out the correct way for Jeffs MOPAR and my non MOPAR project...
Zomby woof
Zomby woof Dork
3/7/11 7:06 p.m.
Those Pony motors are the same (1.6) motor that car originally came with, and they're stout as hell. I've built my share of them, and just scrapped a few complete ones.
I'd go 2.6
Leach
Leach SuperDork
3/8/11 6:08 a.m.
Moparman wrote: Aluminum Hemi?
bravenrace
3/8/11 7:17 a.m.
In reply to Zomby woof:
Not doubting you, but I blew mine with only 37k miles on it.
MadScientistMatt
MadScientistMatt Dork
3/8/11 9:22 a.m.
As this one has had a 4G54 swap, I'd probably pull another 4G54 out of a pickup (this was also used in Mazda B2600s besides the Dodge / Mitsu trucks) or Starion.
guwZnOnNJp6AeWqHNcWRFQXiBDCaitffoqWiZKXPwYrECIac3JaBgyUv0zvZ6JPq
