11/30/22 12:14 p.m.
Fueling up your race car, sadly, doesn’t involve driving up to the pump and alerting the attendant with a toot of the horn or the ding of a bell. There are a few extra steps involved.
Rodan
Rodan SuperDork
11/30/22 12:36 p.m.
So "expert tips" is a Sunoco ad and "bring a funnel"?
C'mon... GRM is better than this.
frenchyd
frenchyd MegaDork
11/30/22 1:01 p.m.
In reply to Rodan :
Actually for a lot of newbies to using racing fuel instead of pump fuel it is a big help.   Yes they mentioned one brand but as we now know there are other brands around.
      Plus places we may not know about.  Snow mobles for example. They tend  to use race fuel because yes they are raced. Motorcycles, race shops gas stations etc.
Then talk to others.   There is a serious difference between pump E85 and racing E85.   E85 in the pump tends to use as low as 51% ethanol and an even lower octane gasoline. In order to keep prices as low as possible.
     Racing E85 uses 15% race fuel and 85% ethanol.   That's what you want if you're pushing really high boost 20-30 40 PSI  not 85 octane gas and 51% ethanol.
     Be aware that Indy cars use 100% ethanol and no intercoolers.  In fact they used to use 85PSI boost and no intercoolers.
      Why not intercoolers?  1 weight ( not just the cooler, but the tube and hoses etc) 2 drag, 200+ MPH adds a lot of drag. 3 restriction of flow through an intercooler air does not like to change direction ( especially at the velocity race engines). ( and it's simpler)
 Remember compressing air heats it up but Alcohol  cools it way down.
SSpiffy
SSpiffy New Reader
11/30/22 1:39 p.m.
Best deal I found for race fuel was at a motorcycle dealership. Beat anywhere else around me.
200mph
200mph Reader
11/30/22 2:06 p.m.
And... get rid of your clear or translucent white fuel jugs.  The "light ends" of race gas are very sensitive to ultra-violet light.  Your fuel will degrade quickly if left outside in one of those jugs.
Some elements including manganese will separate out of fuel exposed to sunlight... it will look like flecks of rust at the bottom of the container.  Agitate (stir) the fuel to disperse it back into solution.
Keep fuel in an opaque container, and keep the container out of direct exposure to the sun (inside is best).
Rodan
Rodan SuperDork
11/30/22 2:08 p.m.
In reply to frenchyd :
Did  you read a different article?  Nothing you mentioned is in the online article.  The info about pump vs. race E85 is useful, however.
200mph has provided a useful tip as well.  Hopefully the thread will continue in that vein.  yes
te72
te72 HalfDork
12/1/22 10:15 a.m.
Surprised nobody mentioned a fire extinguisher...
wFthhfDkfwlZG8hQ7T4REzcuu90nXsoaaDJrSny8LE3UDwrIzcmZFUDQu28VYEER
