2 3 4 5
yupididit
yupididit HalfDork
9/10/15 4:01 p.m.
Just gonna put this here
https://losangeles.craigslist.org/lac/pts/5195851173.html
singleslammer
singleslammer UberDork
9/10/15 4:26 p.m.
That is really sweet. Good option for a small car transplant.
oldtin
oldtin UberDork
9/10/15 5:34 p.m.
a little more inspiration
I like running donor cars - all the wires are there to make it work. It's the little stuff that'll kill a swap or triple the cost and effort.
lrrs
lrrs New Reader
9/10/15 6:07 p.m.
yupididit wrote: Just gonna put this here https://losangeles.craigslist.org/lac/pts/5195851173.html
What's one of these little gems weigh?
Edit: Found on GT40s.com "Audi promo propaganda that the lump weights 195kg and is 464mm long" or about 430lbs and 18.27 inches. To heavy for the back of my Kelmark, but if a mid engine chassis ever finds its way to me, this would be perfect.
Edit 2: found another post that stated the 18" is the new chain driven cam engine, the older belt driven where a bit longer.
Trackmouse
Trackmouse HalfDork
9/10/15 7:54 p.m.
Came here to say "1uzfe". That is all.
turboswede
turboswede MegaDork
9/10/15 8:04 p.m.
Trackmouse wrote: Came here to say "1uzfe". That is all.
Bolted to which berkeleying transaxle or transmission?
Come back when your answer doesn't involve a stupidly expensive adapter that winds up making an LSx swap cheaper with more power out of the box.
Flight Service
Flight Service MegaDork
9/11/15 6:36 a.m.
Yeah, that is the beauty of the Audi engine, there are transaxles that you can bolt up. I think I might have found stand alone ECU, but I need to investigate more after work.
Paul_VR6
Paul_VR6 Dork
9/11/15 11:43 a.m.
Megasquirt should run anything before the FSI V8's without issue.
yupididit
yupididit HalfDork
9/11/15 11:50 a.m.
What rwd transmission fit the 4.2 v8?
docwyte
docwyte Dork
9/11/15 11:51 a.m.
That's one of the worst motors Audi has made in a long time. Byzantine (and very expensive!) fire wall mounted timing chain. Motor likes to eat oil, drop valves and score cylinder walls.
I wouldn't swap one of those into my car if I got it for free, parts and labor...
92dxman
92dxman Dork
9/11/15 2:03 p.m.
What about one of the Audi 6 pots?
Flight Service
9/11/15 2:28 p.m.
In reply to docwyte:
Are you talking 32v, 40v or the RS engine
Because all are very very different motors
Mr_Clutch42
Mr_Clutch42 SuperDork
9/11/15 7:20 p.m.
In reply to yupididit: That engine requires a wiring harness to run though. Plus, is the factory ECU part of his deal?
just_me
just_me
11/14/16 5:36 p.m.
In reply to BradLTL:
2.5 and 2.7L Boxsters used the Audi 01 (E?) 5-speed transmission 3.2L Boxster Ss used the 911 6-speed, a ZF unit
I am referring to 986 series; 1998-2004.
Grant
markwemple
markwemple UltraDork
11/14/16 6:29 p.m.
Wait until its time for a timing belt change.
Flight Service
11/16/16 5:42 a.m.
I noticed something with this. I believe the VW version of the Porsche transmission will work. Why is this important? Location of the starter cutout in the bell housing. Porsche has it at the top where the other ones are on the side.
From what I have read one from behind a diesel VW works well due to gear ratios and isn't sought out.
In Europe, the Audi V8 is almost the equivalent of the SBC. Common and cheap. I am finding ways to overcome the stock Audi IMO chip that is online, very detailed. After that, it is just running down the associated wires with the Porsche harness and building an adaptor harness to allow the Audi ECU to talk to the Porsche ECU enough to allow the chassis systems to work.
Of course, there are things that aren't foreseen until you sit down and do it, but I believe this is becoming a more feasible swap.
Where this gets really interesting is the idea opens up to the Supercharged V6 that gives the RS line a run for it's money with just a tune.
Figure out that swap and a $3k Boxster becomes a 911 Turbo killer with no cutting required (The Renegade V8 Boxster kit requires some cutting.)
M030
M030 Dork
11/23/16 5:35 p.m.
I really looked into doing this to my own car, but the biggest reason not to is that a 996 Carrera 3.4L flat six engine practically bolts in, makes more power and in the end, would cost less to do. I will prove it with my own 3.4L - into early Boxster - swap. The only useful information I can offer to someone actually contemplating the swap is that it's necessary to use a 2001 or older Boxster as the engine recipient, because as of model year 2002, Boxsters all have CANBUS networks that won't play nice with Audi electronics or (supposedly) stand alone EFI
Vigo PowerDork
11/23/16 6:28 p.m.
So uhh, whats the street value of a 3.4 996 engine?
M030
M030 Dork
11/24/16 7:36 a.m.
Vigo wrote: So uhh, whats the street value of a 3.4 996 engine?
In reply to Vigo:
What does it matter? Crummy/rebuilt salvaged or Crash damaged 996s are well under $10,000, and to offset the cost of my 3.4, I'll selll my over-maintained Boxster 2.5 for as much as I can get for it, then sell the 996 roller. I think I can be all-in and have it running for well under $10k, probably 5k if I'm careful and/or get really lucky selling the 2.5 and 996 roller
emsalex
emsalex New Reader
11/24/16 1:43 p.m.
There are a few mr2s running around with north/south Audi v8s.
M030
M030 Dork
11/24/16 1:56 p.m.
In reply to emsalex:
Seems like an expensive and complicated way to ruin an MR2
Vigo PowerDork
11/24/16 11:05 p.m.
In reply to Vigo: What does it matter?
Well, it matters to ME only in the event that i blow up my 3.4L 996 engine.
If it's a high enough number i may even daydream about swapping an audi 4.2 into my 911.
dean1484
dean1484 MegaDork
11/24/16 11:23 p.m.
I have done alot of research on the 4.2 and if you are thinking of using one of these motors you want a 2004 or earlier as they have the front mount timing belts.
I was / am thinking of a challenge build that involved this motor. I think MO30 knows what I am thinking of doing. It involes creating speed through subtraction instead of through adding go fast parts.
Flight Service
11/24/16 11:24 p.m.
10k for an engine alone compared engine and transmission for <2k
8k seems a bit much to sort through the wiring don't ya think?
Trackmouse
Trackmouse Dork
11/25/16 9:34 a.m.
Bolted to which berkeleying transaxle or transmission? Come back when your answer doesn't involve a stupidly expensive adapter that winds up making an LSx swap cheaper with more power out of the box.
http://www.gt40s.com/forum/attachment.php?attachmentid=23065&d=1188138334 What are you talking about??? It's called a bellhousong adapter and they are not THAT expensive. I've said it many times before, The 1uz will make more power than any LS swap when the budget is even. It's minimum $6,000 for any LS swap into any car. (GM cars that came with one don't count). 500$ for an adapter, 400$ for the 1uz. I'll be into my swap a total of $1,000 when I'm done. That leaves me $5,000 to throw at a turbo kit.
2 3 4 5
8jhvArwbXeNcQ2fP8uinz40cv8NtEKFGht3E8E6DklYmxWXd17oOcGjGwpzYfz7K
