Adrian_Thompson
Adrian_Thompson SuperDork
9/10/12 2:49 p.m.
Is there enough meat on the stock hubs to re-drill them for 4x100?
turboswede
turboswede PowerDork
9/10/12 2:57 p.m.
Not really, though it has been done:
http://www.turbo124.com/forum/viewtopic.php?f=3&t=9689
Also:
http://www.fiatspider.com/f08/viewtopic.php?f=7&t=18562
ditchdigger
ditchdigger SuperDork
9/10/12 3:16 p.m.
I like the idea of drilling the existing holes off center and using a press in stud of a larger base diameter like this method
http://mirafiori.com/dave/s-4x100.html
Adrian_Thompson
9/10/12 3:23 p.m.
ditchdigger wrote: I like the idea of drilling the existing holes off center and using a press in stud of a larger base diameter like this method http://mirafiori.com/dave/s-4x100.html
That seems a good way, but it prevents you going back to 4 x 98 though.
Curmudgeon
Curmudgeon MegaDork
9/10/12 4:23 p.m.
If you don't like the idea of drilling the hubs and losing the 4x98 bolt circle, there's nothing to keep the hubs from being redrilled at 45 degrees to the original bolt circle for a 4x100 bolt circle and those holes tapped for 12 x 1.50 wheel bolts. That way you can use the original wheel bolts to hold 4x100 wheels on and it's super easy to go back to the 4x98 setup. Of course you need to drill the rotors the same way...
ditchdigger
9/10/12 4:49 p.m.
There are two big flats on a Fiat hub. 45 degrees won't work. You will have to go just enough that they fit.
hotlinks seem to be blocked for any site selling Fiat hubs. Click this
http://www.midwest-bayless.com/storefrontprofiles/DeluxeSFItemDetail.aspx?sid=1&sfid=208227&c=192697&i=255555286
It is doable, You just have to bunch the holes up.
I have gone over how to do this a few hundred times. I have a whole machine shop at my disposal and am not afraid to dive into things but I am still using PCD Variation bolts. They work, are inexpensive, perfectly safe and reversible if that is important.
mad_machine
mad_machine MegaDork
9/10/12 5:53 p.m.
Fiat Volumex Rims.. 15" diametre (not sure on the width)
Might be the last set at Bruce's..$420 a piece.
www.fiatparts.com
JThw8
JThw8 UberDork
9/10/12 7:37 p.m.
Still my favorite Fiat wheels.
Adrian_Thompson
9/11/12 2:51 p.m.
Anyone on www.fiatspider.com? I tried joining last Friday, I got the common you need to be approved by an admin to prove your not a spam bot reply and waited over the weekend. Nothing, so yesterday I replyed to the automaticaly generated admin address with a personal note to prove I'm a human, including a link to this thread started by me with the same user name I'm trying to register there. Still nothing. I can't see the classified ad's unless I'm a member. Can anyone over there poke someone please?
Raze
Raze SuperDork
9/11/12 3:52 p.m.
In reply to Adrian_Thompson:
I sent a PM to Mark Allison (So Cal Mark) who administers much of the site, and the site owner, hopefully we can get you going over there.
-Jeff
Kenny_McCormic
Kenny_McCormic Reader
9/11/12 4:34 p.m.
With RWD offset 4x98 cars, use a spacer/adapter to 4x100 and run FWD offset 4x100 wheels.
mad_machine
9/11/12 5:35 p.m.
JThw8 wrote: Still my favorite Fiat wheels.
If you could get those in a 14"... I would be ALL over them
JThw8
JThw8 UberDork
9/11/12 5:49 p.m.
If I could get them in 17 I'd put them on the Abarth. They make reproductions now, they might offer them in 14, not sure.
Adrian_Thompson
9/12/12 8:14 a.m.
Raze wrote: In reply to Adrian_Thompson: I sent a PM to Mark Allison (So Cal Mark) who administers much of the site, and the site owner, hopefully we can get you going over there. -Jeff
thx
Adrian_Thompson
9/12/12 8:16 a.m.
Todays question. LSD's, what if anytihng is available and how much $$'s? Is there something comon that swaps in (good), or are you stuck with buying new at $1k +/- (bad)?
Raze
Raze SuperDork
9/12/12 9:45 a.m.
Collotti ($$$) or lada units (http://www.ladaworld.com/product_info.php?products_id=47) ($$). Swaps for rear ends are Ford 9" narrowed, BMW IRS, older Lancia rear ends, those are just what I've read about...
Adrian_Thompson
9/13/12 8:54 a.m.
Raze wrote: Collotti ($$$) or lada units (http://www.ladaworld.com/product_info.php?products_id=47) ($$). Swaps for rear ends are Ford 9" narrowed, BMW IRS, older Lancia rear ends, those are just what I've read about...
That looks like 3,500 Swedish Krona (I thnk) which is about $530 before shipping, taxes etc. Not tooooooo bad
Adrian_Thompson
9/13/12 12:21 p.m.
Still no luck.
turboswede
9/13/12 12:43 p.m.
I've had better luck at Mira Fiori
h43hAKg9kUA0ySnSEbi8efxOkoIgyfqcdqCu4VXzR8M8jbQKbQcnYZjctiyrqujr
