mblommel
mblommel HalfDork
3/13/16 4:32 p.m.
Hmmmm. I guess I was extraordinarily lucky then. I was successfully welding thin rusty Fiat sheet metal after a few test welds on some scrap. The only welding "theory" I studied was the feed rate/amperage chart sticker on the welder. Shouldn't the roof on a chevy pickup be thicker than an old Fiat?
JThw8
JThw8 UltimaDork
3/13/16 8:31 p.m.
mblommel wrote: Hmmmm. I guess I was extraordinarily lucky then. I was successfully welding thin rusty Fiat sheet metal after a few test welds on some scrap. The only welding "theory" I studied was the feed rate/amperage chart sticker on the welder. Shouldn't the roof on a chevy pickup be thicker than an old Fiat?
^ This, I've welded small holes like this since the day I picked up the welder. This is not rocket science folks, take your time it can be done simply.
dean1484
dean1484 MegaDork
3/14/16 7:42 a.m.
I would weld it but another option would be to lead/solder it. Put a small dimple at each hole with a hammer then apply solder/lead. Sand seal and paint.
I would be comfortable with either way.
gXKGcYDl0IVknDKHDZGM7LNndgW87cU8mXtwxkgyy5sJsUFoXKj3ad1CwZtLUSeb
